Date: 07-05-26  Time: 02:10 am
Author Topic: clutch seems hard to pull  (Read 1916 times)
HarryHornby
« on: 09 April 2014, 10:53:58 am »
Hi All,
Ever since I picked up the bike the clutch has been bugging me.  There is freeplay in the leaver, as there should be and the leaver moves fine until it gets to the biting point.
The biting point is very close to the bars and you have to apply a lot more force to the leaver to get to and past the biting point.
It feels something like the cable is too short and I have to persuade it a bit more for the final couple of mm.  I'm not saying that's the issue because I have no idea, but that's how it feels.  On my old Fazer it was a nice even pressure required to pull in the clutch and I presume the same should be on this bike.
Any ideas?
Re: clutch seems hard to pull
« Reply #1 on: 09 April 2014, 11:50:43 am »
Have you tried adjusting it at the bottom end of the cable?
Chris
« Reply #2 on: 09 April 2014, 11:55:38 am »
try oiling the cable, it might have got a bit gritty/gunged up in there. Might be making the wire stick and not slide inside the sheath properly.
Sounds like it needs adjusting too if it's biting too close to the bars, Like darrsi said there is room for adjustment at both ends of the cable.
Chris
His Dudeness
« Reply #3 on: 09 April 2014, 01:32:05 pm »
the cable might be frayed. sounds like it needs a bit of tlc anyway. like chris says give the cable and mechanism a clean and oil behind the cover and slacken the cable a bit if it's biting too late
