Date: 24-04-26  Time: 22:56 pm
Author Topic: FZS1000 caliper hanger  (Read 14178 times)
emjaydee
« on: 03 April 2014, 03:22:43 pm »
Hi,
Searched through the threads but I can't get a definite answer.
Does a FZS1000 caliper hanger fit on a FZS600?
Thanks
Chris
Re: FZS1000 caliper hanger
« Reply #1 on: 03 April 2014, 04:01:05 pm »
no
emjaydee
« Reply #2 on: 03 April 2014, 04:05:58 pm »
Thanks
Chris
« Reply #3 on: 03 April 2014, 04:10:28 pm »
No worries  :D
To be less blunt, I believe the internal diameter of the spidle is larger on the 1000 so would be loose on the 600. The overall hanger might be too thick too which would mean it wouldn't fit between the wheel and swing arm.
The 600 hanger is easy to mod so the 1000 calliper fits though. You know how to do it?
Chris
« Reply #4 on: 03 April 2014, 04:17:16 pm »
Since i bare a small amount of responsibility here i trawled through & can see a quote from fizzy
The FZS1000 and XJR1300 (blue spot 2002+) are the same part. I think in '06 or '07 the xjr1300 was upgraded to a silver spot and is supposidly better still.
+1 to what FF says. The mounting holes are the correct pitch, the only mod required to is the 600 caliper bracket, theres some metal in the way, not much, just enough to make the 2nd hole not line up untill its filed back, two minute job i did mine on the breakfast bar with a g clamp and half round file, shhhh dont tell SWIMBO  Unquote
Thats what i was on about by saying you needed a file...i hadnt realised it was on the 600 mount but obviously you have one of them already.
« Reply #5 on: 03 April 2014, 07:20:02 pm »
Did it arrive then Emjay???
emjaydee
« Reply #6 on: 04 April 2014, 12:05:22 am »
Yes and no.....had it going to my in-laws but they weren't in to sign for it, i'll have to pick it up from the post office depot tomorrow.
Thanks for getting it to me so quickly.
pilgo
« Reply #7 on: 04 April 2014, 07:18:17 pm »
had my FZS1000 rear caliper fitted today onto the 600 hanger,as stated above,you put the far end bolt through the caliper and into the 600's hanger and then try to line the other hole up,you will see just how little of the 600's hanger that you will need to grind down,mine was ground down still on the bike.you will have to take a smidgen off the far bolt hole end of the hanger as well
seemed very easy watching someone else do it!!  :lol
good luck
emjaydee
« Reply #8 on: 04 April 2014, 09:12:13 pm »
Pick up the caliper up from the depot today and I couldn't wait to fit on the bike.
First I removed the FZS1000 caliper bracket
Then I inserted left side bolt and offered it up into position to see where it needed grinding. I found that 2 points of the bracket needed grinding.
Using a Dremel, I ground down about 1-2mm from here........
and here.....
then I fitted the torque arm off a Thunderace, which conveniently also arrived today.  Took me around 30 from start to finish (fitting the torque arm took longer that the caliper).
Chris
« Reply #9 on: 04 April 2014, 11:49:57 pm »
Looks spot on mate and good pics to show how to mod the 600 calliper too.
Chris
RMT1983
« Reply #10 on: 23 August 2014, 06:57:01 pm »
So is the 2002+ xjr1300 blue spot the same as the fzs 1000? the look slightly different.......................
kebab19
« Reply #11 on: 24 August 2014, 01:06:13 pm »
I have a 2007 XJR1300 rear caliper on mine (well, technically a silver spot version) and you mod the FZS caliper mounting bracket the same way as you would for the FZS 1000 caliper.
So I guess it's the same.
Pics to follow....some day
tweetytek
« Reply #12 on: 26 August 2014, 12:43:09 am »
Looks good mate, nice 1
Pal
« Reply #13 on: 03 September 2014, 11:27:40 am »
Which year 1000 caliper do I need for this mod?
tweetytek
« Reply #14 on: 03 September 2014, 09:22:39 pm »
:fish read the thread above (inc. noggy's post) and search
Pal
« Reply #15 on: 04 September 2014, 01:11:39 pm »
Yep, did that, it says that the XJR caliper is from 2002 on but nowhere does it mention what year fazer thou caliper to use.
And please stop hitting me with that fish, you're giving me a headache
tweetytek
« Reply #16 on: 04 September 2014, 01:41:54 pm »
Is like to whack it harder.!
It's says the fzs1000 , AND ,#AND#, the xjr ARE THE SAME PART and that the xjr part was upgraded in 06/07 , so by elimination your looking for a model 2002  .. 2005/6 are u not?
« Reply #17 on: 04 September 2014, 02:14:52 pm »
FZS1000 '01-'05
tweetytek
« Reply #18 on: 04 September 2014, 02:43:55 pm »
Yep, that would do nicely.
Pal
« Reply #19 on: 05 September 2014, 01:04:42 am »
Nice edit  :D
Pal
« Reply #20 on: 24 September 2014, 01:30:23 pm »
« Reply #21 on: 24 September 2014, 04:33:53 pm »
I wouldnt mess myself have you seen this thread post http://foc-u.co.uk/index.php/topic,14772.0.html
tweetytek
« Reply #22 on: 24 September 2014, 05:10:49 pm »
Ah but that incident is more likely to do with the guy adjusting his chain without loosening the torque arm bolt , which is what he did, resulting in a twisting force along the arm and thus shearing off at the mounting bracket, which looks like what happened
It has nothing to do with the calliper and there are plenty of them around fitted to fz's
« Reply #23 on: 24 September 2014, 05:39:12 pm »
I supose I shouldnt take this thread off track. And you are right there seems loads that have done it. We dont know if this is what caused kebabs because he has not come back to his post.
But here is kebabs picture before it broke, compared to the OEM it is a lot lower and makes for a greater angle on the arm which inturn puts extra stress on the swingarm mount point. (to me anyway)
Edit--- or has he mounted the hanger differently
tweetytek
« Reply #24 on: 24 September 2014, 05:55:37 pm »
Agreed. I feel we are Saying the same thing
The calliper itself wouldn't seen to be the issue, based on wide spread use, but rather the arm used or the method used to secure the arm (OEM or whatever) to the swingarm mount (hopefully OEM)
