Date: 04-05-26  Time: 21:13 pm
Author Topic: Black is Black  (Read 2557 times)
Andy FZS
Black is Black
« on: 19 March 2014, 03:15:38 pm »
Ok not the song....I've just bought a new old stock Yamaha hugger for my gen1. The problem is they only had one in silver, so I thought I'd give it a quick rough up with scotch bright, a coat of grey primer and then a coat of black from the motor factors. Have I missed anything or is this a plan?
Andy
purplebear7
Re: Black is Black
« Reply #1 on: 19 March 2014, 03:26:49 pm »
Think I'd fit it first .. just to be sure I had not got any hole drilling mods to do .. then remove and paint as required  :\
Stay Safe  ;)  Polar Bear
rustyrider
Re: Black is Black
« Reply #2 on: 19 March 2014, 05:36:27 pm »
Sand down the primer with something very fine (wet 1200 grit) and dry it well before putting the top coat on.  A couple of coats of top coat, then sand again with the 1200 grit before giving it a coat or two of clear acrylic lacquer.
Re: Black is Black
« Reply #3 on: 19 March 2014, 07:17:44 pm »
Andy
Yeh your bike is silver !
Andy FZS
Re: Black is Black
« Reply #4 on: 19 March 2014, 08:21:54 pm »
Ah so should I paint the bike to make the hugger then;)
rayburn600
Re: Black is Black
« Reply #5 on: 19 March 2014, 09:35:48 pm »
Yes
Don't forget you need plastic paint, or paint suitable for plastic. (special stuff)
rustyrider
Re: Black is Black
« Reply #6 on: 19 March 2014, 10:37:37 pm »
Not necessarily.  Standard acrylic spray paint is flexible enough as long as the surface is keyed properly.
Skippernick
Re: Black is Black
« Reply #7 on: 19 March 2014, 10:45:48 pm »
Yes, sand the hugger with more than scotchbrite, although it gives a mechanical key, you need to be a bit more harsh as i assume the hugger is lacquered which you need to get rid of. So 800 grit or so, just be careful on pointy bits.
alan sherman
Re: Black is Black
« Reply #8 on: 21 March 2014, 11:56:08 am »
Just buy a black one!  Must be millions floating around and the manual effort for re-spray seems a bit pointless.
I have a carbon look one.  Better than gloss black as it doesn't show the dirt / scratches so bad.
UG
Re: Black is Black
« Reply #9 on: 22 March 2014, 12:16:01 am »
GERRa nurmull pursun ter fink fur ya den furget evvryfing day sed  anne doo it yerselph der whey
ewe wont two
Andy FZS
Re: Black is Black
« Reply #10 on: 22 March 2014, 12:54:42 am »
One coat adhesive stuff, three coats primer, two coats black, drying overnight.......one more coat of black and then lacquer to finish off..:)
