Date: 02-05-26  Time: 11:59 am
Author Topic: Bike died just as I arrived at work (engine trouble warning light)  (Read 2476 times)
peterjca
My 2008 FZ1 Fazer died just as I arrived at work. I noticed the orange light came on (looked that up, "engine trouble warning light" - erk!!!) and then 15 or seconds later, the console went blank and the engine died some seconds later.
The orange engine trouble light comes on when you switch the bike on (with all the other lights) but then remains on.
Doesn't sound like good news. Off to find a PDF owner's manual...
Tmation
Re: Bike died just as I arrived at work (engine trouble warning light)
« Reply #1 on: 10 March 2014, 01:56:14 pm »
you could try the downloads section on here http://foc-u.co.uk/index.php?action=downloads;cat=4
« Reply #2 on: 10 March 2014, 11:43:09 pm »
Download the manual
Access the diagnostics
Maybe this might be of help
Codes with number at the end of each line from a working Gen2
#01 – Throttle Position Sensor
Full closed – 15-18   16
Full open – 95-100   96
#02 – Atmospheric Pressure Sensor (100 kPa = 29.53 inHg)   102
#03 – Cyl #1 Intake Air Pressure Sensor   102
#05 – Intake Air Temperature   11
#06 – Coolant Temperature   10
#07 – Vehicle Speed   0
#08 – Lean Angle Sensor   0.6
#09 – Fuel System Voltage   11.4
#20 off off (side stand) on   ON
#21 off off ( neutral) on   ON
#30 -> Coil #1   0
#31 -> Coil #2   0
#32 -> Coil #3   0
#33 -> Coil #4   0
#36 -> Injector #1   0
#37 -> Injector #2   0
#38 -> Injector #3   0
#39 -> Injector #4   0
#48 -> Air Induction Sys   0
#50 -> Fuel Injection Sys   0
#51 -> Radiator Fan Relay   0
#52 -> Headlight Relay   0
#53 -> EXUP Servo motor   0
#56 -> Sub Throttle Servo   0
#60 -> EEPROM Fault (Cylinder Number 01-04)   0
#61 -> Malfunction history code. Fault Codes 11-50   0
#62 -> Malfunction history code erasure. Fault Codes 01-28   0
#63 -> Malfunction code reinstate   0
#70 -> Control number   0
and the values for Co
C:01 -5   -5
C:02 20   20
C:03 20   20
C:04 2   2
peterjca
« Reply #3 on: 21 March 2014, 12:06:15 pm »
The error code was 46 (not listed in the manual) which means something is wrong with the power supply. In fact, what was wrong was the generator was f*cked and is currently being replaced. Coincidentally, my trip mileage was 46 at the time so the error code on the dash didn't register as an error code!
Car driving friends of mine can't believe that the new generator parts come to over £800 with VAT.
Having other bits done to the bike at the same time: new exhaust (Beowulf titanium jobby), new OEM rear shock, braided hoses, new clutch and throttle cables, new chain and sprockets, good valet.
Because of this expense, I'll hang onto the FZ1 until 2016 when I'll consider a new bike.
The Male Whale
« Reply #4 on: 22 March 2014, 07:22:45 am »
Most of the parts are Nippon Denso and available from other suppliers rather than Yamaha.
For example, the Reg/Rec in the alternator on my Pan is £220 from Honda, the part from a Nippon Denso dealer is less than £20 and they are making a profit on that £20.00.......
Whale
