Date: 21-04-26  Time: 07:56 am
Author Topic: New chain time - bigger sprocket on the FRONT?  (Read 8939 times)
pointer2null
« on: 28 February 2014, 02:12:26 pm »
It's time for a new chain - the cheapo one I stuck on the old sprockets 3 years ago is approaching end of life.
So, I'm toying with the idea of putting a larger sprocket on the front.  :eek
I'm not interested in pulling wheelies or riding like a dick, I more interested in MPG's on the way too and from work so the loss of accelleration isn't a problem.
Anyone tried anything like this before? How much difference will it make to the ride/MPG etc?
mr self destruct
Re: New chain time - bigger sprocket on the FRONT?
« Reply #1 on: 28 February 2014, 02:16:20 pm »
Would there be any clearance problems inside the cover? I'm thinking a smaller rear sprocket would have the same effect.
pointer2null
« Reply #2 on: 28 February 2014, 02:17:41 pm »
AFAIK you can get away with one or two more teeth on the front.
On tooth on the front is the equivelent of about 3 on the back - hence why I was thinking of doing that rather than changing the rear.
mr self destruct
« Reply #3 on: 28 February 2014, 02:20:12 pm »
Ahh gotcha! I'm thinking about doing the same as I do a lot of motorway miles. Sounds like the front is the way to go.  :)
Hiswitsend
« Reply #4 on: 28 February 2014, 02:40:42 pm »
Have a look at http://www.gearingcommander.com/ you can play about with the ratios and see what the effect on the speed, rpm at speed the change will have
Dave
pointer2null
« Reply #5 on: 28 February 2014, 03:23:19 pm »
thats handy - there was one on the old fazer site.
Gonna go for front +1 and rear -1
See how that goes, it it's too much I'll swap one for a standard.
If I put the back on the front and front on the back I can do 500MPH in 4th  :rollin
adeejaysdelight
« Reply #6 on: 28 February 2014, 11:56:00 pm »
I went 1 down on the front and 1 up on the rear. It makes quite a difference. My riding style is obviously the polar opposite of yours, as I love to ping it about and care not for MPG and motorways. If I have to use the motorway, I'll take the SAAB. But my point is, one tooth at the front either way will make a noticeable difference. If that is done with a change at the rear, it will make a significant difference.
Fraser
« Reply #7 on: 01 March 2014, 12:30:51 pm »
I tried one tooth up on the front, it was very noticeable, sluggish, forever changing down gear to overtake,   fuel comsumption INCREASED, I stuck with it for about 3k miles and then put the CORRECT sprocket back on,    Aaahhh   Lovely
Fraser
« Reply #8 on: 01 March 2014, 12:34:14 pm »
Come to think of it, I've still got the bigger sprocket which you are very welcome to. It's only done 3k, try it on your old chain before you go out and spend money. PM me your address and I will pop it in the post, Fraser
noggythenog
« Reply #9 on: 01 March 2014, 12:35:28 pm »
Good egg!
There be a good egg! 8)
dickturpin
« Reply #10 on: 01 March 2014, 01:11:48 pm »
what a luverly site this is!
ChristoT
« Reply #11 on: 01 March 2014, 03:00:19 pm »
That Gearing Commander site is a tad innacurrate: On stock gearing, it claims a 600 will do 230mph in 6th at the redline. I suspect it isn't taking power into consideration here (or rolling drag, or friction, or aerodynamics....  :lol :lol ), as a bike can only go as fast as its engine permits.
Dead Eye
« Reply #12 on: 01 March 2014, 07:16:18 pm »
That's not a basis of Gearing Commander being inaccurate. The 600 would do 230mph in 6th at the redline... if it had the power to do so
The purpose is to show the gearing ratios and related speeds, not to debate the finer points of whether these speeds are possible or in what time they would be achieved
ChristoT
« Reply #13 on: 01 March 2014, 08:25:22 pm »
True, but then the bike has to have the power to accelerate with the added load upon it.
JoeRock
« Reply #14 on: 01 March 2014, 08:36:26 pm »
I've relatively certain I had mine quite close to the red line about 11k ish) , at about an indicated 150?
mickvp
  • Global Moderator
« Reply #15 on: 01 March 2014, 08:50:55 pm »
I would imagine variations in the rolling diameter of the wheels and tyres will be the major factor there?
Dead Eye
« Reply #16 on: 01 March 2014, 09:18:42 pm »
Apologies, you are correct and gearing commander puts 11,500 RPM in 6th as 143 MPH - Christo's data was wrong, which I didn't verify on the actual site. The dozy muppet was reading KPH not MPH :P
pointer2null
« Reply #17 on: 01 March 2014, 10:59:00 pm »
well i got the chain and sprockets today, +1 front , -1 rear so will fit them sometime in the next few months (wanna eek out the best I can from the current chain) although I don't think the current one will last long now - time between large adjustments (1/2 turn) is down to 3 weeks.
When I start using them I'll post back and let you all know the results. My mpg is consistent at 50 (+- 2) mpg so will see how the fuel consumption is affected.
richfzs
« Reply #18 on: 02 March 2014, 02:52:40 am »
 The dozy muppet
Not the first time that's been said  :rollin :rollin
ChristoT
« Reply #19 on: 02 March 2014, 02:54:12 am »
 The dozy muppet
I've been known to do it myself on occasion! :lol
apage16
« Reply #20 on: 05 March 2014, 12:46:40 am »
I went +2 on the front and -2 on the back.
Still love riding the thing!
plus I get 260 out of a tank. And that was before i fixed the monumental hole in my downpipes. haven't run through a whole tank yet to see the difference.
JoeRock
« Reply #21 on: 05 March 2014, 12:52:30 am »
I still have no idea how you can ride like that chap, pulling away must be bloody nightmare, and I can't imagine how slow it would accelerate! Cruising speed on a motorway would be like 3k revs!
apage16
« Reply #22 on: 05 March 2014, 12:57:01 am »
Check a few of my youtube efforts out Joe. I know it's not like riding it yourself, but you can kinda see that it still goes!
http://www.youtube.com/playlist?list=PLQyyGnBe8LfeF36-r3cTMQO9aKZCsd3nL
And it's doing about 4000 rpm at 60, ( i think, haven't ridden of for a couple of weeks!)
Dead Eye
« Reply #23 on: 05 March 2014, 10:33:37 am »
According to Gearing Commander that would be accurate and I can't see it being a particularly huge difference for cruising - the 1000 at stock does 60mph at 4000 rpm
The lower gears will be more noticeable, but if you are just commuting you are still going to be able to pull away from lights / stops faster than cars can :)
ChristoT
« Reply #24 on: 07 March 2014, 12:40:21 am »
It probably wouldn't be dissimilar to my restricted bike, but rather better!
