Date: 07-05-26  Time: 12:26 pm
Author Topic: Front Sprocket Cover  (Read 3789 times)
Lazarus
« on: 14 February 2014, 08:04:29 am »
Hi,
Trying to remove the Front Sprockey cover on FZS600 '03 - is it just a matter of undoing the 5 holding bolts?
I've already removed the left hand footrest and linkage. 5 bolts are "out" but cover doesn't want to "shift".
don't want to use anymore force in case I break it (im good at breaking things)
TonyW
Re: Front Sprocket Cover
« Reply #1 on: 14 February 2014, 09:53:58 am »
You have taken the gear selector lever off the shaft haven't you?
Lazarus
« Reply #2 on: 14 February 2014, 09:57:07 am »
ive taken the left footrest off, complete with the joining bar to the "cogged" wheel on the outside of the casing. the cog is still in place on the bike
adeejaysdelight
« Reply #3 on: 14 February 2014, 10:12:46 am »
You don't need to take the footrest off, just the gear selector. Give the cover a little tap tap with a rubber mallet.
NOTE -a little tap tap, not a big bang bang.
That should be enough to free it. And put a little copper slip on there when you re-fit it.  :thumbup
wezdavo
« Reply #4 on: 14 February 2014, 10:16:52 am »
+1 for rubber mallet
Skippernick
« Reply #5 on: 15 February 2014, 10:45:07 am »
Don't forget to get cross and skin your knuckles :lol
alan sherman
« Reply #6 on: 18 February 2014, 10:09:08 am »
Pull the clutch lever.  It levers off the cover.  Remember this for when you are riding along and  the clutch starts to fail soon after replacing the blots with stainless ones ;)
« Reply #7 on: 18 February 2014, 01:46:01 pm »
Lazarus
« Reply #8 on: 23 February 2014, 10:04:42 pm »
got it off - cleaned it up and put it all back together all on my ownio.
Fecking chuffed with meself........until I remembered the reason for taking it off was to check the bolt.
old age.....
