Date: 04-05-26  Time: 06:07 am
Author Topic: FZ6 Fazer bar dimensions  (Read 5147 times)
expatmanxman
« on: 23 January 2014, 05:06:22 pm »
I wonder if someone can help me out. I have an FZ6N and want to raise the bars by just a small amount, there's very little spare cabling so can't just fit a pair of high renthals. Does anyone have the dimensions of a Fazer handlebar, width and rise mainly.  If I can find the dimensions \i can look at which renthal is closest.  I priced up a pair of Yamaha Fazer bars, nearly 50 quid!!!!!!!!!!!!
Other alternative is to fit bar risers but the only ones I've seen are 25-30mm which I think will be too much for the length if cable I can get.
chaz
Re: FZ6 Fazer bar dimensions
« Reply #1 on: 23 January 2014, 09:54:29 pm »
Hi the bars on my 05 FZ6N are 680mm wide this is to the end of the grips and excludes the bar ends, the rise is 35mm and the ends of the bars are 100mm back from the centre, this is measured from a straight edge from the end of the bars to the edge of the bars at the middle of where they are clamped, hope that makes sense?
expatmanxman
« Reply #2 on: 23 January 2014, 10:22:25 pm »
Thanks Chaz but I'm after the dimensions for the Fazer bar, I want to fit them to my FZ6N to give me a bit more rise.
Thanks for making the effort :-)
Ianboydsnr
« Reply #3 on: 24 January 2014, 10:22:50 am »
74cm including bar weights, that is straight across!
