Date: 24-04-26  Time: 13:48 pm
Author Topic: Ignition/key problem  (Read 15859 times)
Razgruff
Re: Ignition/key problem
« Reply #25 on: 18 January 2014, 07:31:36 pm »
I did Vaseline regularly my TDM,
TDM ?????? Tiny Dick Member !
I use clear silicon grease for stuff like that (not on my TDM though cause it stings)
 :rollin :rollin :rollin :rollin
Trouser Destroying Monster :smokin
redthunder
« Reply #26 on: 20 January 2014, 02:14:48 pm »
Solid advice folks, will lob some vaseline into it and see if it improves!
Re: getting a new key cut, surely getting one copied off the worn key will just give me a sharper worn key?  :lol
It might need replacing down the line but i'd rather not have to carry a second key to open the petrol tank either!
wickedmonkey
« Reply #27 on: 22 January 2014, 08:53:07 am »
Shoved a small amount of vaseline into the ignition at the weekend. I have to say that it does seem that there is a small improvement.
Razgruff
« Reply #28 on: 22 January 2014, 10:34:21 am »
It won't fix it  :(
but will ease the movement of the worn bits inside, will take a little while for the Vaseline to work it's way around in there to lube up all the bits
