Date: 02-05-26  Time: 17:44 pm
Author Topic: Exhaust Gas Leak - Solution ?  (Read 2279 times)
Enceladus
« on: 22 March 2013, 01:43:26 pm »
hi all
just remembered that my bike is due an mot next month  :eek
i think there is a small gas leak on the exhaust where the end can meets the pipework.
i assume that this would be a fail.
is there anything i can use to stop this that wont look hideous ?
reillypadraig
Re: Exhaust Gas Leak - Solution ?
« Reply #1 on: 22 March 2013, 03:05:11 pm »
I used silicone, clear stuf but after a couple of miles and a couple of bad rough roads later it was loose again and had to scrap it of, quick fix thou,
I found some firegum, like gun gum but it works as a lube at first to ease exhaust pipework onto each other then forms a seal with that lube, have yet to get the funds for it, event though u think its only a tennor. Comes in a tube rather than the gun gum tub
bandit
« Reply #2 on: 22 March 2013, 07:29:29 pm »
This is the stuff you need put a nice thick bead of it around the inside of the endcan & slide on.
 http://www.halfords.com/webapp/wcs/stores/servlet/product_storeId_10001_catalogId_10151_productId_173139_langId_-1_categoryId_255217
Ben600
« Reply #3 on: 22 March 2013, 10:21:00 pm »
the best quick fix I came up with for a blowing silencer / link pipe joint was to cut a coke can, roll it up and use it as a gasket between silencer / link pipe. Works well, looks ok (can't see it) and is cheap and easy!
