Date: 20-05-26  Time: 02:52 am
Author Topic: a little help on spanner sizes  (Read 5466 times)
wfbroddy
« on: 30 May 2012, 08:09:24 pm »
Folks,
need a wee bit of help, I pick my FZ1s up on saturday (I don't think its got the tool kit with it as there s PCIII in there ?, and I want to be able to adjust the gear/brake levers once I've put a couple of miles on her, so what sizes do I need to adjust these levers ??
Cheers
Phil TK
Re: a little help on spanner sizes
« Reply #1 on: 30 May 2012, 08:26:31 pm »
 Get yourself a small set of spanners covering from 8mm to 14mm and you will have most of the bolt/nut sizes covered, Spanners are not expensive thesedays, Machine Mart or Halfords do reasonable quality ones for a few pounds, it's best to get the ones with a ring type wrench on one end and open ended on t'other.
 Failing that, when he wheels your pride and joy out of the workshop/showroom ask the mechanic nicely if he'll spend a minute adjusting your levers to suit you.
wfbroddy
« Reply #2 on: 30 May 2012, 10:25:22 pm »
Ah I maybe didn't make myself clear, I have a garage full of spanners, so having them and sizes isn't the issue  :D
I tend to find I need to be on the bike for awhile till I realise how I prefer the levers, so was just needing to know the size so I can take a couple with me to fiddle with on the return journey to hame  :sun
Falcon 269
« Reply #3 on: 30 May 2012, 10:48:09 pm »
Why not take a spanner or two from your collection and try them before leaving home?  ;)
If that's still not a simple enough solution, I think you'll find that trying a 10mm first might be advisable.
ghostbiker
« Reply #4 on: 30 May 2012, 11:07:58 pm »
I get what you meen. Traveling to pick up your new bike and want to set it up on the return to home trip.
I would plump for 2 screw drivers ( 1 flat 1 pozzi) spanner wise 8 10 12 14, or just a 10 and a small adjustable.
Enjoy your new ride :)
Falcon 269
« Reply #5 on: 31 May 2012, 05:21:19 am »
A gotcha now!  Thanks, ghostbiker. :)
Gear levers rods and rear brake master cylinder adjusters on these are usually a pair of 10mm nuts.  So, 2 x 10mm open-enders or 10mm and small adjustable wrench as suggested should see you right.
mcyoungy
« Reply #6 on: 31 May 2012, 06:49:39 am »
you may find that the front brake lever needs an Allen key on the clamp.
wfbroddy
« Reply #7 on: 31 May 2012, 07:00:59 am »
A gotcha now!  ......
simple eh!  :rollin
Thanks folks, I did suspect a 10mm would work, but coming from beemers over the last few years wasn't sure if the japs did things different  :)
Falcon 269
« Reply #8 on: 31 May 2012, 05:17:27 pm »
PaulSmith
« Reply #9 on: 31 May 2012, 05:38:43 pm »
My mini kit is two 10s, a 12, a small set of allen keys, a stubby flat head, and a stubby pozi, small (bent nose) pliers. A roll of electrical tape, a stanley knife, a couple of pairs of disposable gloves and a collection of zip ties. All wraped in a shammy leather.
wfbroddy
« Reply #10 on: 31 May 2012, 05:59:00 pm »
