Hi, I'm Ferg. Just bought a Fazer that has been sitting outside for a couple of years after it threw a change. Got it through a local bike shop for next to nothing. Its an import as the speedo has a MPH sticker on it and the lights dip to the wrong side. First registered May 2002 but I suspect its a 2000 model. Maybe and expert on here can tell from the photos.
Confession time. My first love is actually my 1999 XJR1300 and this will be my second bike. Sorry if that offends any Fazer lovers!!
Needs a fair bit of work but ill get it running first, MOTd and taxed and then see what I want to do with it.
The chain and rear sprocket are missing along with one chain adjuster. Might be spacers from rear wheel also but need to look into that a bit more first.
Previous owner said that the clutch wont engage since the chain came off. Hopefully its just a bent push rod or something simple.
I will probably be bugging you all for more info once I start work on it. Power washed it this morning!! Photos are pre-powerwash.
