No, the bottom of a wet salt mine.
Believe it or not, this was standard winter riding, I think he just neglected the standard winter rinse off, several times, and then several more, and then threw some salt on it.
At least its better now, sprayed with Tygris bright zinc galv spray, it was the only silver I had. Just ordered some XHT silver spray for the exhaust when it arrives from Devilsyam.
Got a new oil filter, the oil is on its way (Motul 5000) as is the coolant, exhaust gaskets and S/S exhaust studs. Hopefully the knackered pipe and oil cooler top will be replaced with a good set in the next few days, got some stainless jubilee clips for the hoses, just sprayed the radiator up satin black, cleaned up the underseat area including the tool bag (both filthy). Bought a load of stainless socket cap screws and S/S Button heads to replace the rusty bolts. Think i'll spray the coolant pipe and oil cooler gold.
I love working on stuff that whatever you do, you cant make it look worse than it did before!!
