Date: 03-05-26  Time: 02:43 am
Author Topic: Would you tinker??  (Read 9308 times)
dickturpin
Would you tinker??
« on: 06 December 2011, 07:28:10 pm »
Plan on removing the radiator to remove the AIS shortly to fit Justy's kit. I'm tempted while there
to coppaslip the header bolts, but wonder if I'm tempting fate undoing these when I don't really need to.
Am I courting problems or would you do it as well??
acid drop
Re: Would you tinker??
« Reply #1 on: 06 December 2011, 07:30:30 pm »
If you mean the cylinder head bolts  NO dont touch the head bolts cos you will end up destroying the seal between the head and the block
dickturpin
« Reply #2 on: 06 December 2011, 07:33:25 pm »
No, won't be touching them, I mean the exhaust header bolts.
« Reply #3 on: 06 December 2011, 07:48:52 pm »
Well, if you decide to go ahead, doing it with a hot engine will give the best chance of them coming out without shearing. (Aluminium expands more than steel as the temperature rises thus loosening its grip.)
I'd be inclined to leave them alone but, if I was going to take them out, I'd replace them with stainless ones as well as giving them a dab of copaslip.
limax2
« Reply #4 on: 06 December 2011, 07:57:58 pm »
Mines a FZS600 and I do the header nuts every year and reapply some copper grease. Never had a problem, but if your's have not been done before and they don't slacken fairly easily I think I would be inclined to leave them alone. Maybe apply some easing oil on them a day or two before you attempt it.
PieEater
« Reply #5 on: 06 December 2011, 08:21:30 pm »
Insert cliche - ......if it aint broke ......... can of worms ....... fettle in haste regret at leasure (ok I made that one up) ...........
richfzs
« Reply #6 on: 06 December 2011, 08:23:38 pm »
sure I've heard it before though :)
kebab19
« Reply #7 on: 06 December 2011, 11:05:01 pm »
Are they badly corroded?
Spray them every day with Plusgas for a fortnight then use decent fitting sockets
Mine came off easily but then again no guarantee yours will
SEPTIKANGEL
« Reply #8 on: 06 December 2011, 11:09:36 pm »
Got Justy's kit too - winter project.
Read your post with interest, considered the same with bolts too, but some good advice here.
'If it ain't broke, fix it 'till it is!'     :rollin
or........
'Why do today, what you can put off  'till tomorrow' (Homer Simpson) :lol
Think I'll be leavin' mine alone. :rolleyes
dickturpin
« Reply #9 on: 07 December 2011, 12:07:10 am »
They aint badly corroded, bike hasn't seen much wet weather at all.
Maybe you should go first Septikangel!!!!
Warming up the engine with the radiator off could be interesting!
Falcon 269
« Reply #10 on: 07 December 2011, 08:01:11 am »
I'd do it because I believe in prevention being better than cure.  You'll be able to tell from the first one whether it's going to be a breeze or a pain.  If it's the latter, you can always bail out at that point.
If they're not obviously corroded, wire brush the exposed stud thread and squirt some penetrating fluid on them.  Leave to work while you're doing the AIS removal.
Undo one nut at a time, copper grease and replace.  Move on to the next and so on.  You'll likely be surprised at how easily they undo as they're not torqued tightly.
No need to warm the motor, IMHO.  You want the nut to come off the stud, not the stud to come out of the head. :)
« Reply #11 on: 07 December 2011, 11:32:47 am »
Agreed. The OP was probably inadvertently referring to bolts rather than nuts. :)
ZiggyCol
« Reply #12 on: 07 December 2011, 01:38:13 pm »
Header nuts are one of the things that I believe warrant regular attention because at some point for one reason or another you will want to take the headers off.
So I make a point of undoing and re-greasing at least once a year and have never had a problem. It's a simple job and the potential pitfalls of ignoring it (sheared studs etc.) means it just makes sense.
However this only applies if you can easily achieve it. If you are already past the point of prevention then leave well alone . . .
SEPTIKANGEL
« Reply #13 on: 07 December 2011, 05:23:52 pm »
Yeah, I was thinking 'bolts', but just had a look and it's 'nuts', all of which look in pretty good condition with no crud or rust on the studs.
So I reckon this thread has enlightened me sufficiently to service me nuts while they're exposed.  :lol
Gratitude for the wisdom of my fellow foccers.
Won't be starting it 'till well into new year though Dickturpin, so...... after you!  :D
Silverdream
« Reply #14 on: 07 December 2011, 07:20:08 pm »
Think i will leave mine and go with the.. "if it ain't broke..." theroy...  :lol
dickturpin
« Reply #15 on: 07 December 2011, 08:41:35 pm »
Where are your nuts Silverdream? :eek
richfzs
« Reply #16 on: 07 December 2011, 09:16:07 pm »
bit personal isnt it?
dickturpin
« Reply #17 on: 07 December 2011, 09:50:49 pm »
Was this what Mike had in mind when he recommended a squirt of penetrating fluid!
SEPTIKANGEL
« Reply #18 on: 07 December 2011, 10:21:20 pm »
If that's what they look like without preventative maintenance,  :eek  I WILL be greasing my nuts :)
