Date: 01-06-24  Time: 00:36 am
Author Topic: FZS front end parts needed!  (Read 1766 times)
Arfa
    • Main bike:
      FZ6 S2 07-09
    • View Profile
    • Beginner Biker Adventures
« on: 09 August 2017, 04:06:49 pm »
Need to patch up my FZS 600 (2003 Foxeye), anyone have any of the following:-
Front fairing bracket / stay (preferable not bent!): 5RT-28356-00
Right hand side small fairing bracket: 5RT-2836E-00
Headlight cluster (FZS600 '02-'03 or FZS1000 '01-'05 - same part number), but needs to be UK spec/light pattern: 5LV-84310-10
Foxeye fairing, in one piece, in Deep purplish blue metallic colour: 5RT-2835G-00-P0
Clocks. To swap rear and fuel gauge glass from, any age '98-'03.
b1k3rdude
  • Foc-u Helpful Foccer
  • Global Moderator
    • Main bike:
      FZ1 Faired Gen2
    • - GSF 1250
    • View Profile
Re: FZS front end parts needed!
« Reply #1 on: 10 August 2017, 08:47:12 pm »
  • Front fairing bracket / stay (preferable not bent!): 5RT-28356-00
  • Right hand side small fairing bracket: 5RT-2836E-00
  • Headlight cluster (FZS600 '02-'03 or FZS1000 '01-'05 - same part number), but needs to be UK spec/light pattern: 5LV-84310-10
  • Foxeye fairing, in one piece, in Deep purplish blue metallic colour: 5RT-2835G-00-P0
  • Clocks. To swap rear and fuel gauge glass from, any age '98-'03.
On a scale of rareness -
Arfa
    • Main bike:
      FZ6 S2 07-09
    • View Profile
« Reply #2 on: 11 August 2017, 12:07:45 am »
Yeah, quite aware of rareness, not the first time I've had to replace this lot...   :rolleyes
Spotted fairing bracket in Lithuania, but quite clearly bent... Couple in Germany, but more money than new from Fowlers (£160)!
Never seen the side brackets on ebay, but at least these are only a tenner new.
Light clusters are tricky as foreign ones will have wrong light patten and will dazzle all to the right. Plus all those in US and in EU have some damage with lugs missing. Did consider trying to crack one open to swap reflectors from mine, but lot of hassle. Did see some Chinese knock offs for £100, but they seem to be missing the side lights... Otherwise it's £250 from Fowlers.
There are a couple of DPBMC fairings on ebay, but all damaged. Been offered one for free with only some light damage.
Are clocks for FZS1000 compatible with the FZS600? Look similar enough...
As it happens, I found a breaker on ebay who has done me clocks, front bracket and light cluster for £140. Cluster just missing one lug, so took a punt and will try to repair. Will report back once stuff turns up in day or two. Also bit bullet and ordered (another) new fairing from Fowlers. :-) On back order, so figured I'd order sooner rather than later. And bonus for the day, was my local garage happened to find some FZS600 infills in his local skip, so just gave them to me!
« Last Edit: 11 August 2017, 12:08:29 am by Arfa »
b1k3rdude
  • Global Moderator
    • Main bike:
      FZ1 Faired Gen2
    • - GSF 1250
    • View Profile
« Reply #3 on: 12 August 2017, 02:50:54 pm »
  • As it happens, I found a breaker on ebay who has done me clocks, front bracket and light cluster for £140. Cluster just missing one lug, so took a punt and will try to repair. Will report back once stuff turns up in day or two.
  • Also bit bullet and ordered (another) new fairing from Fowlers. :-) On back order, so figured I'd order sooner rather than later.
  • And bonus for the day, was my local garage happened to find some FZS600 infills in his local skip, so just gave them to me!
  • Ah cool, I am curious to see what they look like, got some shots..?
  • yeah, even buying a sh fairing once you factor in painting you might aswell buy new.
  • I assume of the foxeye 600? got pics and I am not 100% sure these are exactly same the the fzs1000 ones.
Arfa
    • Main bike:
      FZ6 S2 07-09
    • View Profile
« Reply #4 on: 12 August 2017, 03:10:46 pm »
Stuff from breakers turned up:
Bits nearest camera.
Clocks in good nick, got 46K on them - just a spot less than mine. Also confirmed fuel gauge no responding is indeed my old bashed clocks.
Head light missing one lug as expected, but has a scratch on right hand lens. Spent morning plastic welding on lug from my old lights to it.
Bracket was a bit ben, twisted and much rust TBH, needed some time with my rubber mallet to get it back in line. Was hoping for better, but I've got it vaguely straight again and have now Hammerite'd it, so it will suffice. Also got a spare headlight wiring loom in deal too.
Either way, by no means perfect but was a reasonable deal at £140 and will suffice to get me back on road.
Gaz66
    • Main bike:
      FZS 1000 Gen1
    • - VFR800 Fi (1999)
    • View Profile
Arfa
    • Main bike:
      FZ6 S2 07-09
    • View Profile
« Reply #6 on: 17 August 2017, 10:48:22 pm »
http://www.ebay.co.uk/itm/yamaha-fazer-fzs600-1998-2003-front-sub-frame-fairing-stay-bracket-/272753861623?hash=item3f8165a3f7:g:V-oAAOSw0TxZYLBx
Hope this helps matey?
That's an old box eye one, no good to me I'm afraid, not same as later Foxeye ones.
I've picked up isn't the best, and not 100% straight. What do still need, is some of the self tapping screws to bolt headlights to fairing and lights to fairing bracket. Part no. 90164-05001 and 9016705077.
