The tyres are both Michelin Pilot Road 3s, barely done 1,000 miles. Front looked a bit buggered at the scene (looked like a stone had got between the rim and the tyre), but it may be OK on closer inspection. If it is, £120 for the pair? If not, I'd take £70 for the rear.
That towbar WILL save your bike should an old biddy rear end you - happened to a friend, he reckons he would have dropped the bike had it not been fitted. And if your bike were to fall over, it save your rear faring (as I can attest). Consider it a safety device!! There is a standard car electric plug too - Red98 will be able to remove it, and join it to the towbar when the spare key gets there!! It's a bargain, it cost closer to £300 to have the bloody thing built, as it is very heavy duty, plasma cut steel. It bolts on (yes, all bolts) in 5 minutes. Means you can tow a small car trailer 2m long by 1m wide, and weighing 150kg when loaded. The way to show off the track bike when arriving at a trackday!!
Hugger is still available.
If discs are OK (they're half worn, mind, but I don;t think they're warped)- the pair for £80?
Fizzy - just for you, I'll sell you the trailer for £500 - and throw in the towbar for free. Collection from France.
