Date: 20-05-24  Time: 02:18 am
Author Topic: Gen 1 exup valve  (Read 3308 times)
Tuckerhauser
    • - Bmw s1000rr
Gen 1 exup valve
« on: 09 July 2015, 12:30:52 pm »
Know they are like hens teeth but worth a try;-)
after a exup valve for my 2004 fazer
valve that's fitted to mine currently rattles like hell end is worn
Thanks
devilsyam
  • Veteran fazer modder
    • - streetfighter
Re: Gen 1 exup valve
« Reply #1 on: 09 July 2015, 01:11:56 pm »
Easy fix local engineering company ask they to turn down end and make a bush I had mine turned down and used a ball race from a model car worked fine
Tuckerhauser
    • - Bmw s1000rr
« Reply #2 on: 09 July 2015, 02:56:47 pm »
Cheers I'll look in to that, I thought about something like that earlier but was concerned about the material to use.
Something like this http://www.ebay.co.uk/itm/391035683580
« Last Edit: 09 July 2015, 03:01:13 pm by Tuckerhauser »
devilsyam
    • - streetfighter
« Reply #3 on: 09 July 2015, 03:01:36 pm »
Open ball bearing can take the heat
RMT1983
« Reply #4 on: 09 July 2015, 08:43:31 pm »
Is it just the Arm Shaft that you need?
Tuckerhauser
    • - Bmw s1000rr
« Reply #5 on: 09 July 2015, 11:18:24 pm »
only need this bit that hangs in the exhaust "the cradle" bit
The ends of the above part are worn causing it to rattle
Have the cam, spacers mount etc
Thanks
This is bit I need
  • Foc-u Helpful Foccer
    • - GSF 1250
« Reply #6 on: 10 July 2015, 09:20:15 am »
Thats the actual valve, and doesn't look that worn. Have you got a better shot so we can see where the wear is? At a guess Im betting your missing the small spacer that goes on the end that inserts into the hole on the inside the headers, part 13 (90387106u7)
And regarding the bearings in the end-plate and the headers these are phosphor-bronze, I very much dought you can put normal ball based bearings in there due to the heat 200-400c. For a start the great in them would be burnt away, then there the issue of different expansion level of the balls and the shells.
On while we are on the subject, I would strong suggest replacing the cover and plate bolts (number 7, 18) with either Stainless or titainium (I went for Ti, and I've had them for years just moving from one bike to the next)
« Last Edit: 10 July 2015, 09:28:26 am by b1k3rdude »
Tuckerhauser
    • - Bmw s1000rr
« Reply #7 on: 10 July 2015, 09:59:30 am »
Cheers for the reply,
I have the spacer part 13
I'll get a better shot of the ends tonight when I get home.
That was my concern the material to make the bushes out, and my fear with using bearings
devilsyam
    • - streetfighter
« Reply #8 on: 10 July 2015, 10:21:44 am »
Gonna spell it wrong but phos-fur-bronze
Tuckerhauser
    • - Bmw s1000rr
« Reply #9 on: 10 July 2015, 05:13:34 pm »
Tuckerhauser
    • - Bmw s1000rr
« Reply #10 on: 10 July 2015, 05:14:24 pm »
    • - GSF 1250
« Reply #11 on: 10 July 2015, 09:09:28 pm »
Ok, there is wear there. But with all the spacers in-place and the correct amount of slack set on the pully cables you shouldn't hear much of any rattle.
« Reply #12 on: 10 July 2015, 11:04:06 pm »
Thanks
Did you check the wear on the bushes and the housing? Wear on any of these will cause the valve to rattle also.
  I had to replace the bushes on mine after 25000 miles.
Tuckerhauser
    • - Bmw s1000rr
« Reply #13 on: 11 July 2015, 03:29:27 pm »
Wear on the bushes doesn't seem too bad considering 47,000 miles
Deffo slack on the valve spindle, lots of "wobble" and it's just amplifies thru the can
Tried adjusting but was the same, there's a couple of machine shops local to me will have a pop in this week and see wots possible.
« Reply #14 on: 12 July 2015, 07:17:56 pm »
Knock out the bushes and take them with you, they should be able to machine new ones to suit the valve
eddie
  • FOC-U Lost Boy.
« Reply #15 on: 12 July 2015, 08:29:11 pm »
Ear plugs cures rattles.......or if you're  on a goldwing  turn up radio
