Thanks for the guidance, men, I (hopefully) include some photos of the cases. Some angles were difficult because the silver finish on the exterior of the cases reflected back the flash, but I think they give a reasonable view.You can see from the picture on the front of the 'Mounting instructions' perhaps, that they do also fit the FJR. But I can't see the name 'Krauser' anywhere, so I'm not sure, Millietant.These cases are big enough to take a crash-helmet, and can carry up to a maximum load per case of 10kgs. Each has a single key locking system, so there are two keys with the set. There is also a spare lock unit, with which the supplied keys will work. Also, 4 small bolts. I don't know what they are for, but as the cases work without them, I assume they were originally on the bike and were replaced by bolts from the fitting kit.Two plastic parts go with the cases and are also, I assume, taken off the bike and replaced by the fitting kit.I can see 3 on one case, and 4 on the other, tiny blemishes, but they won't photograph as they are too small to show up on the silver finish. There are no large obvious marks. The Yamaha badge on one case has what looks like a very thin line of white paint on part of it. The badge itself is soft, glossy plastic so I haven't tried to remove it with white spirit or thinners in case I damage the surface. When the cases are on the bike, no-one will notice these marks, and from a yard away they are invisible.Let me know if you need anymore info, please.Oh, dear. Using the 'Insert Image' button on the panel above the ad wording box, I imported 10 photos, (I thought!). Now they seem to have disappeared from the 'preview' and this post. How do I get the photos in the ad, please someone?Thanks, Billgee.
Click ATTATCHMENTS......not insert image or modify.......
Ok - but where do I find the 'attachments' button? I can't see it anywhere.
Quote from: billgee on 04 December 2015, 09:47:17 pmOk - but where do I find the 'attachments' button? I can't see it anywhere.Let's start from the beginning.....
