Date: 26-04-24  Time: 04:22 am
Author Topic: Fazer 600 sounding like exhaust blowing but it isn't  (Read 1720 times)
floism
« on: 20 May 2022, 12:41:43 pm »
Hi Folks.
New to the group so hope i posted this in the correct place.
I have a Fazer 600 Year 2000. Just had the downpipes changed because the noise the engine was making sounded like the exhaust blowing. 1 of the studs had broke so when the engine warmed up i thought that was expanding and causing the blowing noise.
Changed oil and filters also.
Did a trip to work and back yesterday (Aprox. 15 mile round trip) and when i got it home it sounded like exhaust blowing again. The noise gets worse the longer the engine been running.
Any idea's of what to look at next would be greatfully recieved.
Thanks in advance
Re: Fazer 600 sounding like exhaust blowing but it isn't
« Reply #1 on: 20 May 2022, 12:49:58 pm »
have you tried to locate where the "blowing" sound is coming from?
Did you get the stud changed? If not, that's the prime candidate.
Hole in the area that the pipes join together?
Problem with the joint between the downpipes and the tail pipe?
Just normal noise from the end can?
floism
« Reply #2 on: 20 May 2022, 01:18:11 pm »
All the studs were changed when new downpipes fitted.
No air coming from around any of the joints and normal noise from end can (Standard can).
Sound like the noise is coming from the engine rather than the exhaust.
Just spoke to a friend of mine (Wish i'd spoke to him before posting lol) and he said because i put E10 in it and then left it stood it could be water in the fuel system that causing noise when engine warms up.It's a stab in the dark but i'm going to drain fuel system this weekend and get some superplus and give it a go.
Thanks for your reply BBROWN1664
« Reply #3 on: 20 May 2022, 01:28:53 pm »
just out of interest, what do you have your idle speed set to? too low and it can sound odd. Should be 1150-1250rpm
floism
« Reply #4 on: 20 May 2022, 02:09:24 pm »
Idle speed just over 1000rpm.
Noise gets worse as revs get higher. It sounds like a tank but only when it gets warmer.
After i've had a go at the fuel this weekend (Weather permitting) i'll let you know if it makes a difference or not.
Any other ideas that come my way will be greatfully recieved as it's doing my head in. (And my wallet lol)
« Reply #5 on: 20 May 2022, 02:31:53 pm »
maybe post a video up on here so people can hear it
floism
« Reply #6 on: 20 May 2022, 03:07:41 pm »
Good thinking about the video.
I'll post it over the weekend as working later.
Thanks
  • Foc-u Brake Doctor
« Reply #7 on: 20 May 2022, 06:22:47 pm »
If it's not blowing from the header.  What exhaust is fitted standard OE or replacement?
Later
      FZ6 04-06
    • Affordable Leather Products
« Reply #8 on: 20 May 2022, 08:15:25 pm »
Just to check, get a rag or put on a thick glove and block the end of the exhaust pipe.
This should muffle the exhaust noise enough so you can hear if any gas is escaping, also, if the engine doesn't stop, there's definitely a leak somewhere.
« Reply #9 on: 21 May 2022, 11:09:18 am »
Years ago a mechanic had my carbs off and on refitting he accidentally folded one of the rubbers in on itself causing an air leak. And as it was #3 carb it wasn't easy to spot either so was only found after he removed them again.
It was enough of a leak to cause bogging down on acceleration though, so was quite noticeable for me as soon as I rode it home. It's another area that could be checked though, if it sounds like it's from the engine.
floism
« Reply #10 on: 22 May 2022, 05:46:24 pm »
I took the silencer off today just to check the joint between that and the downpipes and found a tiny hole under the clamp in the silencer pipe.
Tomorrow there will be an addition of a Guinness can and some exhaust paste lol.
Thanks for all that replied with info and ideas. It helped
Cheers :)
« Reply #11 on: 23 May 2022, 05:27:26 am »
Cheers :)
You sure that's not a drainage hole, and meant to be there?
floism
« Reply #12 on: 23 May 2022, 10:59:46 am »
Definitely not meant to be there.
Rust hole and it's on the top of the pipe not the bottom.
midden
  • Operation Foc-UTree
    • - Falcon Stealth
« Reply #13 on: 23 May 2022, 11:53:09 am »
Did a trip to work and back yesterday (Aprox. 15 mile round trip) and when i got it home it sounded like exhaust blowing again. The noise gets worse the longer the engine been running.Any idea's of what to look at next would be greatfully recieved.
At a guess I would say the above cancels out the the E10 idea
« Reply #14 on: 23 May 2022, 03:53:35 pm »
Have you torqued up the header bolts recently?
When the pipes are removed then put back on they need a bit of settling in due to vibration, especially when new crush gaskets have been used.
FazThou
« Reply #15 on: 25 May 2022, 04:36:02 pm »
I take it you actually removed the old gaskets before you fitted the new ones?
« Reply #16 on: 25 May 2022, 07:28:22 pm »
Was actually gonna suggest that as well.
When I bought my bike my headers were blowing a bit and I found two sets in there when I went to replace the gaskets.
