Date: 01-05-24  Time: 00:33 am
Author Topic: hi all  (Read 2470 times)
yamasaki
    • Main bike:
      FZS400
    • - Bandit250VC
    • View Profile
hi all
« on: 21 January 2016, 07:42:34 am »
I'm 29 from Asia, I bought my naked mod fazer400 no long ago( sorry for my poor english :b ). This bike is a little bit old, but the enginne is still good, the machine idle speed is very stable, and it start very easy. There is only 2 problems on it, first, it's cluch will slip when you try switch gears in a high rpm. The second problem is the 3rd Carbs had leaking of fuel several days ago, but it recover after I clean the carb, and I don't know when will leaking again, so I add a fuel filter to the fuel hose. This is a black bike, I take this photo at night, so it's a little bit dark. :evil
fz400
fz400
before that, I already have 2 suzuki and a yamaha.
bandit250
bandit250
suzuki
suzuki
ybz125
ybz125
« Last Edit: 21 January 2016, 07:48:45 am by yamasaki »
still like the old time rock n' roll
  • Never ride faster than your guardian angel can fly
    • Main bike:
      FZS600 02-03
    • - FZS1000 05-06, Serow 2000
    • View Profile
Re: hi all
« Reply #1 on: 21 January 2016, 08:56:46 am »
Welcome to the fold, :thumbup what country are you in? Asia is a big place  :lol
That naked 400 is a rare machine, a few came like that as standard and were used for rider training in Japan with a few modifications. I have only seen one ever in the UK. There should have been a small fuel filter in the fuel line as standard.
Your leak sounds like dirt in the needle valve and drain the carb float bowl normally clears it.
The red Suzuki with the red cam cover is the one with variable valve timing, not to many of them over this way.
That one looks very clean.
What model is the black Suzuki?
mtread
    • Main bike:
      FZS600 02-03
    • - Triumph Speed Trip & Tiger 800
    • View Profile
Re: hi all
« Reply #2 on: 21 January 2016, 09:13:57 pm »
By the way, your English is very good. Better than some of ours  :)
yamasaki
    • Main bike:
      FZS400
    • - Bandit250VC
    • View Profile
Re: hi all
« Reply #3 on: 22 January 2016, 01:10:39 am »
Hi Unfazed, nice to meet you due. I'm from southern part of China, Wuzhou city. Naked Fz400 is mod with Yamaha Xjr400's panel, inicators, bar and mirrors and so on... It's very popular here, it's beacaus the weather here is warmer than Europe, it will easier to get cooling when you getting nake. :D  it won't snow here in the winter.
Yeah, the red Suzuki is GSF-250 A.K.A Bandit, and the variable valve timing we call VC, when over about 7000 rpm it works with higher camshaft to make more powerful output, it's something like HONDA's VTEC.
And the black Suzuki is EN-125, I think it's only sell in China. 125cc bikes is very usual seeing here, over 95% of bikes are 125cc.
« Last Edit: 22 January 2016, 01:29:22 am by yamasaki »
yamasaki
    • Main bike:
      FZS400
    • - Bandit250VC
    • View Profile
Re: hi all
« Reply #4 on: 22 January 2016, 01:30:09 am »
Thank you.  :)
    • Main bike:
      FZS600 02-03
    • View Profile
Re: hi all
« Reply #5 on: 22 January 2016, 08:09:09 am »
Interesting and very effective modification and it looks very like the training model in Japan.
How did you get the Speed odometer to function, did you just use the wheel sensor and speed odometer cable from the XJR400?
The FZ400 and FZS600 share  the same disks and wheels as the XJR400.
yamasaki
    • Main bike:
      FZS400
    • - Bandit250VC
    • View Profile
Re: hi all
« Reply #6 on: 22 January 2016, 11:22:46 am »
It was mod by it's last owner, and I don't know how he did this. All I know is that speed odometer is not precise, it go double times as fast as the really speed :( .
mtread
    • Main bike:
      FZS600 02-03
    • View Profile
Re: hi all
« Reply #7 on: 22 January 2016, 11:08:24 pm »
Sometimes you can buy reducing gears that correct speedometer readings. Might be worth investigating.
Welcome to the best and most friendly owners forum on the internet. We have many owners in different countries (have a look at the members map) but I think you are our first from China, so a special welcome.
yamasaki
    • Main bike:
      FZS400
    • - Bandit250VC
    • View Profile
Re: hi all
« Reply #8 on: 23 January 2016, 04:37:20 am »
Thanks mtread, It's my pleasure to join this forum. I've check out the members map, sure I'm the first one from China.
The reducing gears you mention about I've never heard of it, which web I can buy one?
mtread
    • Main bike:
      FZS600 02-03
    • View Profile
Re: hi all
« Reply #9 on: 23 January 2016, 06:14:59 pm »
One of these can be used to convert from kilometers per hour to miles per hour, so will reduce the reading by approximately half ( 0.62). http://www.ebay.co.uk/itm/SPEEDO-CABLE-KPH-TO-MPH-CONVERTER-29-99-FREEPOST-TOP-MOUNT-MECHANICAL-/331727103526?hash=item4d3c79e626:g:K4YAAMXQ3kNTghD0 You need to check whether the fittings are compatible with your bike, and you may find it cheaper in China
yamasaki
    • Main bike:
      FZS400
    • - Bandit250VC
    • View Profile
Re: hi all
« Reply #10 on: 25 January 2016, 12:47:25 am »
Thank you Mtread, well that's a great mod part, I will consider about it.
