Hey guys.
It's that sad time of life when you have to say goodbye to your Fazer.
I had a bad year with her last year, two accidents and a spill, but I kept her going despite having a new daughter on the way.
Unfortunately, it's coming up to MOT time, and I cant afford to do the necessary to get her up to scratch.
I'm still using it as a run-around, and the engine still pulls well. She's got about 45-50,000 on the clock (i think) and has some cosmetic damage (including a dented tank).
I had to have the front sprocket welded on after the nut threaded it, and it probably needs changing.
I fitted some stainless downpipes and a beowulf can, but the can has a small dent and scuff, and the downpipes need a good polish.
The front right fork seal cover has now gone, and to be honest, I feel sad every time I look at her.
I want her gone. I'm not a mechanic, so I cant validate if the parts are sound, but I know how to use a spanner, and I've had the engine out before so I could check and replace the valve shims (with the help of a friend).
So i'm looking for about £400 (so i can embarrassingly buy a scooter to get to work) or I will break if there is enough interest.
Cheers for stopping by.
