Date: 28-04-24  Time: 17:49 pm
Author Topic: exhaust wanted (not standard)  (Read 2920 times)
BT
    • - bmw 1150 gs
« on: 27 March 2012, 11:01:50 pm »
looking for an aftermarket exhaust
road legal
removable baffle
nice sound but not to rattle the windows
straight fitment to 600
can't decide what I want so maybe if someone has one to sell it might make up my mind for me..
Brian...
craigybee404
Re: exhaust wanted (not standard)
« Reply #1 on: 28 March 2012, 08:55:35 pm »
I have a pipewerx s/s oval can with link pipe i will try up load a vid later
BT
    • - bmw 1150 gs
« Reply #2 on: 29 March 2012, 11:53:16 am »
some pics or video would be good thanks
brian
chunk166
    • - Mountain bike
« Reply #3 on: 29 March 2012, 12:40:10 pm »
This a Delkevic can without the baffle,it cost £126 inc p&p if you buy 1 ask for the 350mm as the 450mm is too long IMHO!
Delkevic can on my Yamaha FZS600 Fazer
chunk166
    • - Mountain bike
« Reply #4 on: 29 March 2012, 12:46:59 pm »
Some Pics Too
Fazer Jake
« Reply #5 on: 29 March 2012, 08:05:38 pm »
i hope you engine was warmed uo  ;)
chunk166
    • - Mountain bike
« Reply #6 on: 29 March 2012, 08:14:22 pm »
Oh yes!   :D
scottomus0
« Reply #7 on: 29 March 2012, 08:24:06 pm »
Where did you buy that from? did you fit it yourself?
chunk166
    • - Mountain bike
« Reply #8 on: 29 March 2012, 08:34:50 pm »
You can get them on Ebay like i did or direct from Delkevic & yes i fitted it myself very easy to do  :thumbup
craigybee404
« Reply #9 on: 29 March 2012, 08:43:18 pm »
Video wont upload but here is a pic
scottomus0
« Reply #10 on: 30 March 2012, 02:49:13 pm »
great thanks. How easy is easy to do? Im certainly no expert unfortunately!
chunk166
    • - Mountain bike
« Reply #11 on: 30 March 2012, 05:57:39 pm »
It is quite simple,there are only 2 bolts to undo.
1st undo the clamp where it joins the down pipes,
2nd the bolt on the footrest/exhaust hanger & pull it backwards,
when you take off the old can you need to take off the nut which is held in by a tab just bend that enough for the nut to come out.
 There should be fitting instructions with your new exhaust,but if not when you assemble it, put gasket in the link pipe,then slide it to where it joins the downpipe,don't forget to put the small clamp on too,(try to do it on the sidestand so you can line up the mainstand with the stop),
then put the strap around the silencer,push the can on the link pipe,line up the strap where it bolts to the footrest but make sure it is on the outside not the inside of the hanger like the suggest!!
When your happy its all lined up tighten it all up.
(((((WHAT I WILL SAY IS, WHEN YOU ORDER IT,MAKE SURE YOU ASK FOR THE b SHAPED EXHAUST STRAP)))))
Good Luck
Ray
scottyboy2203
« Reply #12 on: 01 April 2012, 04:51:10 pm »
is there any effect on fueling with these new cans? would the carbs need re-jetting or anything like that?
chunk166
    • - Mountain bike
« Reply #13 on: 01 April 2012, 07:08:02 pm »
I haven't noticed any change & it runs just as good with stock air filter & jets. I went to Lincolnshire last weekend 230miles each way & managed 170 miles b4 filling & only used about 13 litres of fuel,so i reckon its its about the same as a bog standard silencer just a lot louder  :D :D :D
Fazer Jake
« Reply #14 on: 01 April 2012, 08:23:56 pm »
Changing the end can had no effects for me, however changing the downpipes also fuel dropped by about 4 MPG with K&N
Makes sense, more power = more fuel  8)
