I thought it was meant for the oil coolant but, even in the diagram you linked, that part isn't there.
OK, thanks. I'll try and source the part.I was looking for the hose that went from the oil cooler to the main water hose on the diagrams. I STILL can't see it in the diagrams for the Fazer so I'll pretend I have a Thundercat instead!Cheers all! I'll let you know if it all works.
I meant that I was specifically looking for the hose that joins the oil cooler and water hose together. I'm now looking for the part you mentioned but it's not an easy part to find. Who would have thought a 21 year old part would be so difficult?!
The hose is fine. It is the metal join part that was linked above that has rotted away and snapped off. I can just remove all the hoses, insert the metal join and then re-attach them all.Can't find that part anywhere though so was wondering if I could just pull this part off a 2003 R6? I know it is the wrong shape but I can resolve that with getting some new, longer hoses from, as you say, Halfords. I mean, it is just a metal pipe with 3 holes in it. Surely anything like that would do the same job, even if from a different model, make and year of bike? Or am I being dumb again??
Quote from: McMike on 08 May 2021, 02:16:00 pmThe hose is fine. It is the metal join part that was linked above that has rotted away and snapped off. I can just remove all the hoses, insert the metal join and then re-attach them all.Can't find that part anywhere though so was wondering if I could just pull this part off a 2003 R6? I know it is the wrong shape but I can resolve that with getting some new, longer hoses from, as you say, Halfords. I mean, it is just a metal pipe with 3 holes in it. Surely anything like that would do the same job, even if from a different model, make and year of bike? Or am I being dumb again??FFS buy the proper thing https://www.ebay.co.uk/itm/174753748659?hash=item28b02296b3:g:~OwAAOSwhClgjaCi
Good god!!! I searched eBay for hours and didn't find that!! Brilliant. Thank you so much!
