Date: 25-04-24  Time: 13:14 pm
Author Topic: oil sight glass black  (Read 2505 times)
kwick-kwack
« on: 02 September 2021, 11:29:00 am »
My oil level glass has gone black is there any way to clear it without removing it
  • Foc-u Brake Doctor
Re: oil sight glass black
« Reply #1 on: 02 September 2021, 02:30:00 pm »
Is there oil in the bike?
Later
kwick-kwack
« Reply #2 on: 02 September 2021, 04:40:53 pm »
Yes plenty but can't see through the glass and oil light on. Just done an oil change, put 3.5 litres in light on, put another .5 litres in and light still on
FazThou
« Reply #3 on: 02 September 2021, 06:53:02 pm »
The oil sensors are very sensitive so just try adding a touch more, hopefully the glass will clear a bit with new clean oil in it
kwick-kwack
« Reply #4 on: 02 September 2021, 08:56:23 pm »
It's already got 1/3 extra in
dangerousdave
« Reply #5 on: 05 September 2021, 12:01:31 am »
« Reply #6 on: 05 September 2021, 08:52:11 am »
From what you're saying there's now 8.5lts in there which is way too much and will completely fill the window.  Drain all the oil out and put back the correct amount half of the window. Start the bike let it idle for a few minutes, checking for leaks. Turn it off after couple of minutes check the oil level, top up to half if required.  Then do oil bolt gallery check as per the manual
The oil light level being on is a switch issue, often nothing more than dirty/carroded contacts. At worse the switch needs replacing.
Later
« Reply #7 on: 10 September 2021, 05:14:28 pm »
are you sure its not overfull preventing you from seeing through the dirty oil?
The oil switch could be foocced as Gnasher says above.
fireblake
« Reply #8 on: 15 September 2021, 01:16:08 pm »
I use a small but bright LED torch.
Mickey
midden
  • Operation Foc-UTree
    • - Falcon Stealth
« Reply #9 on: 20 September 2021, 10:29:46 am »
Or the oil light may also be set to come on for extreme overfills
« Reply #10 on: 20 September 2021, 08:14:04 pm »
New sight glass is your best option and is about £20. Part number was  4h7-15361-00, but  it has been superseded by part number 2h7-15361-00.Don't know of any effective way of cleaning it or anyway of removing it with damaging it.
« Last Edit: 20 September 2021, 08:15:32 pm by unfazed »
fazerscotty
« Reply #11 on: 21 September 2021, 07:44:10 pm »
In the dim and distant past, I've used cotton buds on some bikes to clean the glass.
« Reply #12 on: 22 September 2021, 02:44:58 pm »
As have I, Scotty, but the issue with the FZS600 is trying to get at it, you might be able to get at it with the sump off, which means taking the exhaust off. For a €20 it wouldn't be worth the trouble
