will the rear wheel fit a 01 600 5dm fazer?
minimum 4.2mmremember I don't think the previous owner liked corners as its been squared off a bitbut this could be a cheap solution to keep you on the roadyour welcome to come and have a look
I don't suppose you have a luggage rack or Bagster cover for it? Just picked up a T'cat for work.
Quote from: gerkin on 19 January 2014, 06:43:01 pmwill the rear wheel fit a 01 600 5dm fazer?Just so you know- it's exactly the same wheel!If you're selling/buying it with the sprocket carrier and sprocket the cat has less teeth on the back (1 or 2)It's hardly noticeable and can happily use it!
