Date: 30-04-24  Time: 20:14 pm
Author Topic: Owdo  (Read 559 times)
Iain
Owdo
« on: 02 April 2019, 06:11:02 am »
Owdo, folks.
IveI just got my self an 03 fazer thou.
Its crackin bike.
Now, just a slight problem with it. There's some play in the rear wheel bearings . My question is, how do you remove the needle roller bearings
steve 10562cc
    • - KAWASAKI Z1000
Re: Owdo
« Reply #1 on: 02 April 2019, 11:11:31 am »
Welcome aboard and enjoy your new bike, There will be someone along shortly to welcome you and give you the answer to your problem wheel bearing.
Re: Owdo
« Reply #2 on: 02 April 2019, 01:02:37 pm »
Welcome aboard,
Usually the needle bearing does not give trouble and replacing the most likely suspect the bearing on the disc side will resolve the issue.To remove the bearing, remove the disc side dust seal the retaining circlip, remove the sprocket hub and cush drives. remove the spacers
Push out the disc side bearing first and then with a close fitting drift push out the needle bearing housing. You may need to apply some heat to the hub to assist the removal of the needle bearing housing.
Download the manual in the downloads section for torque setting and see what the exploded views of the wheel and other items
Re: Owdo
« Reply #3 on: 02 April 2019, 08:57:00 pm »
Owdo, this is the intro section. Post your question in the Thou Corner for someone to respond quickly. Not many people look in here.
