Yes... I did say that I had tested it with a multi-meter...
it shows the correct change in resistance as the switch is operated
So mentioning twice that I had tested the switch and it was ok wasn't making it clear... have you been to doctors after your crash?
But if the clutch is in then the engine shouldn't engage and the wheel wouldn't move - but the chain doesn't appear too tight. Looks as though it might be too loose if anything
To be honest I really don't expect it to be a mechanical fault due to one test that I did- Engine off, in 1st, clutch pulled in - won't start
Quote from: Dead Eye on 02 September 2013, 09:10:17 pmTo be honest I really don't expect it to be a mechanical fault due to one test that I did- Engine off, in 1st, clutch pulled in - won't startBike has to be in neutral if the the side stand down to start. With the bike in gear, the side stand must be up and the clutch must be pulled in to start. Since it starts in neutral and the side stand tests correctly then the next test must be the clutch switchBypass the clutch switch by removing the wires to the clutch switch and connect them together with a piece of wire. Does the engine start? If it does replace the clutch switch.
Quote from: unfazed on 02 September 2013, 10:05:40 pmQuote from: Dead Eye on 02 September 2013, 09:10:17 pmTo be honest I really don't expect it to be a mechanical fault due to one test that I did- Engine off, in 1st, clutch pulled in - won't startBike has to be in neutral if the the side stand down to start. With the bike in gear, the side stand must be up and the clutch must be pulled in to start. Since it starts in neutral and the side stand tests correctly then the next test must be the clutch switchBypass the clutch switch by removing the wires to the clutch switch and connect them together with a piece of wire. Does the engine start? If it does replace the clutch switch.Have you tried starting the bike with the side stand up, if it should start try engaging gear (with side stand up) it should not stall, also if you have a centre stand try engaging gear with the bike on the centre stand and the engine off, try turning rear wheel it should not turn, now pull in clutch, wheel should now turn.
