Do you notice any engine running problems as a result of the speed sensor not working? If so can you say what the symptoms are?
Quote from: Ruby Racing on 13 January 2013, 04:24:12 pmDo you notice any engine running problems as a result of the speed sensor not working? If so can you say what the symptoms are?Like what? It's nothing to do with the engine?
When the lugs break on the speed sensor, then it doesn't turn in the wheel, so the clock just shows 0mph because it is simply not moving.When it happened to me i don't remember any needle bouncing about, it just didn't do anything.I have a feeling the 3000rpm you're on about is an error code for the TPS.
An electronic fault maybe, but not if it was a broken lug issue, it would be reading the bike as not moving.
May i ask why you want to remove it anyway?
Whereabouts are you? I think I have one
I'm from Ireland, Quote from: Dead Eye on 13 January 2013, 01:12:41 pmWhereabouts are you? I think I have one Not sure if the speed sensor directly affects the ignition coil on this model.Can't tell if it is affecting the bike as my carbs have to be replaced so bike isn't running great at the minute.So this sounds common enough??
