Diagnostic set-up (beware, it's quite long-winded!) - first off, unplug the fuel pump.
With IGN OFF and kill switch ON, press Select / Reset together, turn Ign ON (keeping Select / Reset pressed for at lest 8 seconds) - all displays should disappear except clock / tripmeter.
Press Select until DIAG appears on the clock display (CO adjustment appears as an option here). Pressing Select / Reset for 2 seconds confirms selection of DIAG mode.
Kill switch OFF.
Cooling fan relay is DIAG code 51 - (Select goes through codes upwards, reset goes through codes downwards); turning the Kill Switch ON should actuate the fan relay 5 times (you should hear it click; you may need to remove the back panel to hear it click).
As a quick check of your immobiliser transceiver (the black box near your ignition switch that reads your key), follow the wiring to the connector (six pins); with a test meter, go between black wire (on the loom side, ie the one connected to battery) and the red / white wire - you should have battery voltage. Then go from black wire to the red / green wire and again you should have voltage. If you have voltage, your transceiver is likely KO'd, if you have no voltage, you have a wiring / earth fault.
