Date: 19-01-20  Time: 10:36 AM
Author Topic: winter maintence ,what you got planned ?  (Read 1857 times)
    • - fzs600, hon400/4, suzX7, honCB
Re: winter maintence ,what you got planned ?
« Reply #50 on: 30 December 2019, 04:47:54 PM »
more fazering today......cleaned up the swing arm and shock and refitted ,locked the back wheel and the clutch basket nut came off easy  :thumbup .....other things to attend to over the next few days and not sure when i`ll next be in the garage,really want to get to the problem before i go back to work on thursday and get the parts ordered........next job will be to drop the sump and get my first look at the pump.....
« Last Edit: 30 December 2019, 04:50:29 PM by red98 »
coffee
      FZ1 Naked Gen2
« Reply #51 on: 31 December 2019, 07:19:12 PM »
beautifull day here in south bucks even the sun came out  :) .....back in the garage this morning,took the downpipes off and refitted the rad,connected all pipes and filled the system,started the old girl up with no exhaust so i could clearly see where the leaks coming from and...........
THE OLD GIRL SOUNDS FANTASTIC WITH NO EXHAUST    :lol :lol :lol
as UNFAZED has already predicted its coming from the water/oil pump and draining out through a sleeved hole in the sump,ive drained the coolant and oil in readyness to whip the pump out and inspect the seals , stopping for lunch whilst everything drains...
pleased with my progress this morning but my "parcel of goodness" has arrived.......things might just slow up a bit now    ;) ......see btm piccie   :D :D :D :D
what have you got? LOTUS?
« Reply #52 on: 01 January 2020, 07:29:05 PM »
oh yesssss....a lotus elan would be nice  :lol .....sadly not,but i do have a 74 2002 bmw sharing the garage with the two fazers..........
agricola
  • Man on a mission
      FZ6 S2 07-09
« Reply #53 on: 01 January 2020, 07:37:06 PM »
Damn good clean for a start. Bikes never been so dirty. Blow dry, then on with the ACF50 and the spray gun. This time next year itll probably be the valve clearance check
« Reply #54 on: 04 January 2020, 01:03:27 PM »
a quick update.......sump,oil strainer and large oil pipe are now off  :thumbup .......with a struggle though,laying on the cold,hard garage floor with my head wedged between bike and floor is not good  :\ ......front end is still off the bike, rear wheel is on the floor and ive winched the front of the bike up as high as i can get it without taking all of the weight off the centre stand,its workable but i think its going to be worse getting things back on......
seriously thinking about work bench,abba lift or eazyrizer now........eazyrizer is top of my list as it will lift any bike without the need for having various adapters.....already seen VNA`s excellent sky lift ....anyone got an eazyrizer ?
« Last Edit: 04 January 2020, 05:40:37 PM by red98 »
« Reply #55 on: 05 January 2020, 12:33:46 PM »
more struggling and swearing this morning but the pump is now off the bike  :thumbup ........next job is to split the two halves of the water pump and withdraw the shaft and inspect bearings and seals........glad its out but its been a struggle with the bike on the floor,all i can think off as a quick fix for making it easier to put back together is a series of large wooden blocks , i have a winch more than capable of lifting the whole bike which will give me room to slide the blocks under the wheels and centre stand.......not 100% sure  this is a good idea though    :rolleyes
« Last Edit: 05 January 2020, 12:35:22 PM by red98 »
« Reply #56 on: 05 January 2020, 06:12:21 PM »
got the pump stripped down this afternoon , cant see any major fails and the bearings are excellent ,so just looks like general wear and tear , will order a full O ring set for the pump,sump and clutch cover gasket, and O rings for the large oil pipe as one fell apart as i removed the pipe.....
« Last Edit: 05 January 2020, 06:15:04 PM by red98 »
    • - Mk 1 Speed Triple
« Reply #57 on: 06 January 2020, 08:50:12 AM »
Nice job Mr.Red. What mileage is on your thou?. Just wondered if this fault is mileage related, or just bad luck. I can see how the Sky Lift would have made life a lot easier for you, that's for sure.
« Reply #58 on: 06 January 2020, 09:38:27 AM »
Red, what coolant did you have in it. Strange colour on the internals of the pump.. Had you changed the coolant at some stage?
« Reply #59 on: 06 January 2020, 07:06:58 PM »
hi MR R.......bikes done about 54.000,no service history with the bike when i bought it,but think it may have had a hard life early on ,no signs of abuse on stripping down and am pretty sure its not been opened up before...think ive just been unlucky ,not seen it mentioned on here before either....
yep my nights sleep are full of abby dreams  :lol        think i`ll make some wooden blocks at work tomorrow   :thumbup
« Reply #60 on: 06 January 2020, 07:18:01 PM »
hi UNFAZED,ive had this brown tint in the coolant for a while now,searching my own posts i flushed the system through with HOLTS RAD FLUSH back in july 2017 , it cleared most of it and the header tank is still nice and clean which was the reason for the flush , was a bit surprised myself at the colour,pictures taken without any cleaning .......time to confess.....i use the same anti freeze in the bike as i do in the car    :eek ......BLUECOL UNIVERSAL ANTI FREEZE.................
« Reply #61 on: 07 January 2020, 01:30:00 AM »
I would not think the clear Bluecol U is really suitable for the Fazer or any car with an aluminum engine and radiator.
 Blucol red is probably the better of the two being  Ethylene Glycol based and suitable for high performance aluminium engines
The colouring issue may be due to the previous owner having the coolant changed and using the incorrect coolant type.
What is the inside of the large pipe going into the engine like?
« Reply #62 on: 07 January 2020, 06:46:17 AM »
hi UNFAZED.......thought as much with anti freeze  :o .....will choose carefully for the refill :thumbup ....re the pipe, do you mean the one that exits through the front of the block between the cooler and oil filter ?........not checked that yet but will do this evening....
« Reply #63 on: 07 January 2020, 09:59:29 AM »
Red, no the long one with the drain bolt that goes directly into the pump. 2 seals on it
The one on the block suffers badly from corrosion being directly in the salt spray line.
Mine had a lot of corrosion around where the seal sits last time I had it off
« Reply #64 on: 07 January 2020, 07:28:41 PM »
ah.....think i have the right one now,it looks very good but will get two new O rings   ;)
« Last Edit: 07 January 2020, 07:30:46 PM by red98 »
« Reply #65 on: 07 January 2020, 07:35:42 PM »
made this today and will do another tomorrow, one for the centre stand and the other for the rear wheel (no front end on the bike at the moment). only 100mm , but every little helps...... :thumbup
« Last Edit: 07 January 2020, 07:36:33 PM by red98 »
« Reply #66 on: 07 January 2020, 10:21:18 PM »
Red, yep that Looks pretty good what about the inside of it?
« Reply #67 on: 07 January 2020, 10:55:04 PM »
very clear and bright on the inside  :thumbup ......was going to order the parts needed tonight but ive just run out of steam  :o ...busy tomorrow so perhaps on Thursday,which will leave the weekend clear for a good clean and check,unless of course mrs red knows different  :rolleyes
bigsteve
    • - GSX1100G FZS600SP ER5
« Reply #68 on: 09 January 2020, 03:35:02 PM »
I bit the bullet at weekend taxed 600 and took it on a 180 ride to skegg and back with a few friends for fish and chips to test the mods i have done
 { R6 shock and thou rear caliper }
  and i must admit i am over the moon suspension is spot on with the sag set for my weight  front and rear and the rear brake is such a improvement
   loads of smiles per mile  :D :D
« Last Edit: 09 January 2020, 03:40:32 PM by bigsteve »
« Reply #69 on: 09 January 2020, 09:24:13 PM »
nice one Steve  :thumbup .......thou rear caliper is on my list aswell,when i can find one.......
made up another wooden block today and ordered most of the seals/gaskets,spent £40 but i still need O rings for the "water pump drain pipe" and the "large oil pipe" that i had to remove to get the pump out,cant find them without spending silly money so i might just buy an assorted O ring pack and hope the right size is in there,also need an oil filter which i`ll pick up at halfords on the way home tomorrow.....
bigsteve
« Reply #70 on: 10 January 2020, 11:42:14 AM »
   thanks Red caliper well worth the investment and still have a serviceable 600 caliper as a spare  :lol
         next job replace radiator on ER5 then lower and add pretty bits to partners new to her ER6N before I can start getting thou ready for summer
   O and few jobs on friends bikes
   :rolleyes :D :lol
« Reply #71 on: 11 January 2020, 11:42:52 AM »
got the mighty thou on the blocks this morning.made things a bit easier for the rebuild . parts should be with me for next weekend so thats as much as i can do this weekend .plenty of other projects to keep me busy this weekend though   ;)
« Reply #72 on: 13 January 2020, 07:02:08 PM »
postie bought lots of goodies today  :) ....just waiting for the O rings now and i still need to get down to halfords to get the oil filter
 :o ..........should be ok to start the rebuild at the weekend  :thumbup ....
« Last Edit: 13 January 2020, 07:03:49 PM by red98 »
« Reply #73 on: 13 January 2020, 08:58:58 PM »
Wheels out and tyres off this afternoon. Discs off tomorrow, hopefully with no dramas, bearings out, and off to the powder coaters.
mtread
« Reply #74 on: 13 January 2020, 10:50:06 PM »
Morris fuel stabiliser in the tank. ACF50 over the delicate bits. Wire brushed and repainted the centre stand.
I'm working on the basis 'if it ain't broke, don't foc it up'  :D
