Date: 16-04-24  Time: 20:47 pm
Author Topic: Fuel tank breather hose leak  (Read 4422 times)
binarystarr
    • Main bike:
      FZS 1000 Gen1
    • View Profile
« on: 11 April 2012, 01:35:51 pm »
Hi all
Just noticed fuel is dripping from the fuel tank breather hose.
Any ideas as to what could be causing that?
Falcon 269
    • Main bike:
      FZS 1000 Gen1
    • - Yamaha R1 1999
    • View Profile
Re: Fuel tank breather hose leak
« Reply #1 on: 11 April 2012, 01:46:33 pm »
You sure it's the tank breather hose and not the carb overflows?
If the latter, suspect sticking float (fairly significant outflow, though), a leaky float needle (not common) or a leaky float needle seat O-ring (a lot more common).
http://www.yamahafz1oa.com/forum/showthread.php?t=103599&highlight=found+carb+failure+mode
Phil TK
  • up yer..
    • Main bike:
      FZS 1000 Gen1
    • View Profile
« Reply #2 on: 11 April 2012, 02:10:12 pm »
My FJ suffered from that until I got the carbs out and cleaned the bowls and float pivot -and replaced o rings and needle jets. However a temporary cure that often worked was to whack the errant carb bowl a few times with the end of a wooden hammer handle.
locksmith
  • FOC-U Official Selfish Bastard
    A bit of a cheapskate
    imageJune 09
    • Main bike:
      Other
    • - MT-09 :)
    • View Profile
« Reply #3 on: 11 April 2012, 03:02:04 pm »
I concur, a couple of sharp taps on the carb bowl can be effective.
binarystarr
    • Main bike:
      FZS 1000 Gen1
    • View Profile
« Reply #4 on: 12 April 2012, 10:28:53 am »
Many thanks guys, haynes manual arrived today so will be out this weekend with the tool kit.
I suspect i may have possibly overfilled the tank but this is a good excuse to get my hands dirty and check a few things over.
taksi
    • Main bike:
      FZ1 Faired Gen2
    • View Profile
« Reply #5 on: 12 April 2012, 08:53:41 pm »
My injected '08 FZ1 does it as well in the sun. No carbs to bash so any other ideas?
Taksi
Taksi
Falcon 269
    • Main bike:
      FZS 1000 Gen1
    • - Yamaha R1 1999
    • View Profile
« Reply #6 on: 12 April 2012, 09:57:03 pm »
Just a wild guess ... too much fuel, expanding when it gets warm?
binarystarr
    • Main bike:
      FZS 1000 Gen1
    • View Profile
« Reply #7 on: 13 April 2012, 04:04:59 pm »
Falcon, i think thats more than likely the problem. Only thing is it didn't leak until several days after filling. I guess it may take a while for it to condense and make its way down the tube.
I'm not too worried. Will keep an eye on it and get greasy in the meantime.
Falcon 269
    • Main bike:
      FZS 1000 Gen1
    • - Yamaha R1 1999
    • View Profile
« Reply #8 on: 13 April 2012, 10:23:10 pm »
Leaking due to overfilling/expansion would normally be immediate to my mind.
Has it been raining on the bike recently?  I wonder if you've had water get around the tank cap and find it's way out via the overflow hose.
