Hi Folks,
I’m trying to strip the forks to change the leaking seals on my FZS 1000 Gen1, but having difficulty loosening the damper cartridge bolt at the bottom of the shock – As expected, its turning the entire damper unit inside, without loosening ….
With my previous bikes I’ve always made my own tool to poke down the fork tube to hold whatever it was that was turning.
Intending to do the same here, but can anyone help me out with the (approximate ?) dimensions of the top part of the Damper Cartridge ?
Found a Yamaha Service Tool (# 90890-01447) on the web – from the pic it looks pretty easy to make up, (or at least something that will work), but it would be helpful if someone could give me an idea on the sizing – save me a bit of trial & error.
Anything else I need to look out for ?
Cheers/
