Could you make up an adaptor box with an electric motor governed by the pulse rate from the existing sensor?
The obvious question has to be why they want to go for such old technology?How about this as an alternative.Take the guts out of the mechanical speedo and the standard speedo and switch them over. That way you get the look of the old one but with the modern electrical drive.
so if someone wants to know what speedo drive to use when converting to a mechanical speedo meter.The answer is a speedo drive and caple from a Yamaha YZF 600 Thundercat.Yamaha retainer cluch 341-25846-00-00Yamaha Drive washer 341-25149-00-0its a perfect fit, just plug and play.Have a nice day.
Quote from: ordni on 12 August 2016, 09:58:24 amso if someone wants to know what speedo drive to use when converting to a mechanical speedo meter.The answer is a speedo drive and caple from a Yamaha YZF 600 Thundercat.Yamaha retainer cluch 341-25846-00-00Yamaha Drive washer 341-25149-00-0its a perfect fit, just plug and play.Have a nice day.How do you negate the Rev counter error code when the ecu realizes it doesn't have a speedo connected (from memory generated after raving past 10k in gear)?
Does it switch between showing code and rpm or show code constantly until reset
