Yes, tank off (easy enough, 2 screws, detach fuel line and gauge wire)
Battery out, remove side panels and rubbers, loosen rubber boots on back of carbs, slide airbox backwards. Remove choke, fuel pipe, coolant tubes, loosen rubber boots that attach the carbs to the engine and then a right faff removing the throttle cables as you slide the carbs out to one side.
It's not rocket science and takes about half an hour, a bit longer and a bit more swearing to get back in, pushing the carbs into 4 rubbers and reconnecting throttle cables is a bit fiddly. it'll be worth getting yourself a Haynes manual.
Brett
