A fully charged battery reads 13.8V, when connected to a charger. As soon as it rests for a while the voltage drops to somewhere between 12.5 and 12.8V. Have observed this many times when charging my battery during winter. And this is also on par with the manual. It says to wait for 30 minutes after charging for the final voltage to settle.
If the battery is proven to be fine (because new) I would investigate the starter.
Try something for me..does the bike start with the hazards switched on and do the revs rise and fall in time with the flashing?
... why was I getting 14.12v output with only 10.12v going in??
(Please take care to have your multimeter set to the right position: AC for the white leads, DC for the battery voltages.)
Under load the voltage on the white wires can be below 12V.
I just replaced the regulator on my sons 2003 Foxeye 600 and everything had tested ok, but it was failing under load and the only real indication was a faltering at around 7 to 8000 revs when riding aggressively.
I would be inclined to change the regulator/rectifier first as there are plenty of spares and it is a Shindengen SH719AA
How long has the present battery been in the bike, and what make is.
Yes, I've just seen Fazerider's post, it's been a very long time since I learned about RMS voltages... The question is: Are those values that that other post mentions (90v!) correct? If I disconnected the plug from the stator to the rectifier and measured that, without load, rather than the input to the RR, would I get them then?
... Are those values that that other post mentions (90v!) correct? If I disconnected the plug from the stator to the rectifier and measured that, without load, rather than the input to the RR, would I get them then?
