Use either of two methods: A) measure 465 ml per fork leg B) measure 132 mm air gap (room from the surface of the oil to the top of the fork without the springs and with the fork fully compressed) Note 1: It is very important to have the numbers correct and - even more important - the same at both sides. If you miss out on this, it may result in poor handling and even have disastrous consequences. Note 2: Measuring air gap is recommended over measuring volume, and not especially more difficult, it will be more precise and yield better results. You can use any measuring device dropped in at the desired length and fill until the oil slightly touches OR you can overfill and suck out the excess oil with a hose that you drop in at the specified depth. Note 3: Recommended oil is a grade 10W fork oil. Addendum: You can tweak you forks according to your liking, e.g. by putting 15W grade fork oil in or reducing the air gap by a few millimeters.
Not a bad idea. It probably loses a few cc when it settles...
Hi focs,I 've got a 2001 fzs600 and i am changing fork oil with 15w.There are two amount-air gap specs that i found:1)98-00 models, 475ml -121mm air gap2)02-03 models, 465ml - 132mm air gapWhich one should i follow?My forks are with adjusters on top.Thanks,Aris.
Sorry for the late reply,but i wanted to "feel" the bike before i give a feedback.As many before me have said,the 15w i believe is a "must" uprgade.At least for those who ride at bouncy-shity-not so good roads like me,here in my country.I also upgrade my hadlebars,from renthal's ultra low to lsl's street bars,and the feeling i get from the bike is the best i ever got from it.Ofcourse sag settings were checked.The lsl bars have less sweep and are lower than renthal's and with the stiffer front end it became spot on for me!I plan also a future spring upgrade,as i like the positive upgrade of the front end.As for the bars,i have an ktm's superduke headlight conversion,so i dont know if they will interact with the fzs fairing!Overall a big YES from me!
Quote from: mars696 on 26 November 2014, 06:02:57 pmSorry for the late reply,but i wanted to "feel" the bike before i give a feedback.As many before me have said,the 15w i believe is a "must" uprgade.At least for those who ride at bouncy-shity-not so good roads like me,here in my country.I also upgrade my hadlebars,from renthal's ultra low to lsl's street bars,and the feeling i get from the bike is the best i ever got from it.Ofcourse sag settings were checked.The lsl bars have less sweep and are lower than renthal's and with the stiffer front end it became spot on for me!I plan also a future spring upgrade,as i like the positive upgrade of the front end.As for the bars,i have an ktm's superduke headlight conversion,so i dont know if they will interact with the fzs fairing!Overall a big YES from me! playing devils advocate: wouldn't replacing old degraded 10w oil with fresh 10w oil give a improved feel anyway and if the case then any advantage gained in using 15w would come as extended service intervals
Yes, if I understood correctly, they're used for tuning the mixture. The idle knob is on the side, these are under the carbs, not easily accessible. He said they were turned way too much, so the engine was receiving too much air, which caused difficult starting when hot and irregular idling.Yes, but he was honest and said he went a few times for a ride and tuned the suspension to what he thinks is good in his opinion, so when I arrived he said to go and do a test drive to see if he should soften it up or leave it as it is.Since I liked it, we left it as it is.
