Date: 22-10-20  Time: 12:23 PM
Author Topic: engine knock  (Read 5947 times)
hawkyzf
    • Main bike:
      FZS 1000 Gen1
    • View Profile
engine knock
« on: 19 August 2014, 12:02:26 PM »
 hi,i need help with a knocking sound that is coming from the motor-only when hot,between 2000-3500 rpm,mostly evident on the overrun(when coming back
down),with no load.no knock if under load (holding front brake in first gear at same rpm) knock disappears above 3500 and does not affect riding,vibration.engine clutch and gearbox seem
smooth,just this knocking sound...deep knock in the lower part of the motor,has only done 15000 miles-2001 model........i have changed the oil and filter-no metal chips or flakes,the knocking is evident in neutral/stationary and no knock when moving or under load (chain and sprockets are new)..as it's a knock more than a rattle i don't think the camchain or tensioner are the problem--i could be wrong though--the knock is only there at 85 degrees and above (operating temp) and is louder on the way back down from 3000-2000 revs at a standstill in neutral,it sounds like big end but i thought that would be more evident under load,this seems to be the opposite...any help would be greatly appreciated ........
« Last Edit: 19 August 2014, 10:44:13 PM by hawkyzf »
BIG MAC
  • Thinks custom titles are stupid!
  • New site same sh1te ;-)
    • Main bike:
      Other
    • - FZ1 Fazer, FZS600
    • View Profile
Re: engine knock
« Reply #1 on: 19 October 2014, 08:40:51 PM »
Have you checked the clutch and carb balance?
The Frying Scotsman
hawkyzf
    • Main bike:
      FZS 1000 Gen1
    • View Profile
Re: engine knock
« Reply #2 on: 31 December 2014, 06:23:38 PM »
found the problem......the clutch boss spring had broken,taking out two clutch plates and the clutch hub bearing was knackered....replaced the clutch hub bearing,full set of plates and new boss spring-all back together and running fine..and no noise :D
