OK. access the ignitor unit. Its under the rear cowling so you will need to take this off. Take off grab bars. (4 allen bolts). Take off cowling note the screws under the cowling (metal and those plastic type things) underneath on both sides of the cowling. The ignitor unit has several plugs (harness) going into it; one harness has three wires of colour: BLUE, YELLOW, BLACK/BLUE . Remove that harness. Remove the TPS harness at the TPS sensor end (you've already done that if you have followed my instruction above). TPS Harness has the same colours. You now have two harnesses in your hand which are both ends of the TPS lead (one from TPS, one into Ignitor) Using the meter in CONTINUITY mode, check for continuity across all three wires. ie. touch BLUE on one harness end, touch BLUE on the other harness. "BEEP" ?? If three BEEPS (three colours) come back. If not then check your wiring for breaks/faults - which will be a nightmare as you will need to remove the TPS wiring from the bike so that you are holding these two harnesses on a workbench as one single end to end cable.If you get three BEEPS, come back - wiring is good and the fault is likely to be the TPS unit which we can check simply and replace simplyAs you own a fluke I'm presuming you are not a novice in electrics so am I ok to dispense with the electrical dumbing down - so as not to unduly patronise you and make this post much simpler
Just a minor point , an ECU = Electronic Control Unit as far as my electronic engineering MSc went - also referred to as ECM (Electronic Control Module) which are typically multifunctional and manage various logic circuits associated with automotive applications - new vehicles ECU are quite advanced and include all sorts of applications from tyre pressure to advanced driving modes. However this subject Fazer unit is - as I observe the simple wiring diagram - only preoccupied with the service of the ignition system so technically is an ICU (Ignition control unit) although yamaha termed it a Ignitor. Very minor point not changing the diagnostic for arieljt
.,.Does the Acronym ECU also stands for Engine control Unit
Quote from: unfazed on 03 August 2014, 01:08:48 pm.,.Does the Acronym ECU also stands for Engine control Unit +1 for the correct term ...'Acronymn' rather than using 'abbreviation' ... Perfect grammar !
Welcome to the club
so how is the testing going ??? is it a case of no news = good news
I didn't see you edited it, sorry for that.I followed your guide and the manual now and its seems that the TPS unit is faulty, the resistance is 20-26 M ohm and it's the same between the black-blue and the black-yellow. I tested numerous times and even tested my fluke multimeter with simple resistors just to make sure its not the fluke fault.Could it be that it's the TPS? because if I leave it disconnected and start ignition the tachometer still does the same thing as in the video i posted.Now i'm wondering if I should buy a new TPS unit? (where in Germany?) or I should go to a bike service garage? (and possible have them overcharge and lie to me)
Where does the needle go when you unplug the TPS with the ignition switched on (not with engine running)?
With everything plugged in and you turn on the ignition switch the rev counter goes to 5000 and then slowly returns to 0? YesWith the TPS disconnected it does the same thing? YesWith everything connected, Start the engine and leave it running for 5 minutes. What happens with the rev counter? Only 0-5K as alwaysPost the result/s as it could be an issue with the clocks????? I don't know, but I'm pretty sure the TPS is faultyJust to satisfy me and to absolutely sure you are performing the test correctly.1. Disconnect the TPS - Check2. Attach the meter leads to the 2 outer pins of the TPS unit on the Carburettor? What is the reading? Around 20Mohm - 26Mohm3. Now Attach the meter to the lower and centre pins of the TPS. What is the reading? 23Mohm4. Now with the meter still attached to the lower pin and middle pin, twist the throttle slowly to fully throttle. What is the result on the meter as you twist the throttle and when it is at full throttle? It reacts to the throttle twist and it moves from ~23Mohm to 1.5 Kohm
If the TPS is unplugged it will show 3000rpm, which would suggest the TPS is not the problem.
