Bikes, Hints'n'Tips => Fazer 1000/FZ1 corner => Topic started by: Mustang on 17 April 2018, 09:40:24 pm
anyone have a set of decent used discs for sale?
Ebay (https://www.ebay.co.uk/itm/Yamaha-FZS1000-Fazer-2001-2004-Pair-of-Front-Brake-Discs/182749188047?fits=UKM_Make%3AYamaha%7CUKM_Model%3AFZS%7CUKM_CCM%3A1000&hash=item2a8cb34fcf:g:B5AAAOSwLlpZrqDe) or Partfinder (http://partfinderuk.co.uk/) are the way to go, you can get a good set for under £150.
Also You should always check used disc rotors, see the following guide -
- https://www.motorcyclenews.com/new-rider/choosing-kit/2006/november/mar23-05-how-to-fit-brake-discs/ (https://www.motorcyclenews.com/new-rider/choosing-kit/2006/november/mar23-05-how-to-fit-brake-discs/)
I was hoping someone on here might have a set, don’t want to pay £150 each.
I did say set, its under £150 for the pair chap - - £139, these look very clean and hardly worn (4.85mm) - https://www.ebay.co.uk/itm/Yamaha-FZS1000-Fazer-2001-2004-Pair-of-Front-Brake-Discs/182749188047?fits=UKM_Make%3AYamaha%7CUKM_Model%3AFZS%7CUKM_CCM%3A1000&hash=item2a8cb34fcf:g:B5AAAOSwLlpZrqDe (https://www.ebay.co.uk/itm/Yamaha-FZS1000-Fazer-2001-2004-Pair-of-Front-Brake-Discs/182749188047?fits=UKM_Make%3AYamaha%7CUKM_Model%3AFZS%7CUKM_CCM%3A1000&hash=item2a8cb34fcf:g:B5AAAOSwLlpZrqDe)
- £117, some wear but look to be still within tolerance (request thinkness before purchase) - https://www.ebay.co.uk/itm/2004-Yamaha-FZS-FAZER-1000-2001-2005-Front-Disc-s/361970137626?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49130%26meid%3D376da403c246454a984f0a6080443624%26pid%3D100005%26rk%3D6%26rkt%3D12%26sd%3D182749188047%26itm%3D361970137626&_trksid=p2047675.c100005.m1851 (https://www.ebay.co.uk/itm/2004-Yamaha-FZS-FAZER-1000-2001-2005-Front-Disc-s/361970137626?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49130%26meid%3D376da403c246454a984f0a6080443624%26pid%3D100005%26rk%3D6%26rkt%3D12%26sd%3D182749188047%26itm%3D361970137626&_trksid=p2047675.c100005.m1851)
- £99, a bit more wear but again within tolerance (4.5mm) - https://www.ebay.co.uk/itm/Yamaha-FZS1000-FZS-1000-2-01-Front-Brake-discs-Bremsscheibe/322511528354?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49130%26meid%3D376da403c246454a984f0a6080443624%26pid%3D100005%26rk%3D5%26rkt%3D12%26sd%3D182749188047%26itm%3D322511528354&_trksid=p2047675.c100005.m1851 (https://www.ebay.co.uk/itm/Yamaha-FZS1000-FZS-1000-2-01-Front-Brake-discs-Bremsscheibe/322511528354?_trkparms=aid%3D222007%26algo%3DSIM.MBE%26ao%3D2%26asc%3D49130%26meid%3D376da403c246454a984f0a6080443624%26pid%3D100005%26rk%3D5%26rkt%3D12%26sd%3D182749188047%26itm%3D322511528354&_trksid=p2047675.c100005.m1851)
Tolerance is between 4.7-4.3mm with the lower limit (time to replace, being 4.0mm)
Thanks I’ll take a look
Pair for sale on the forum right now £100. Check the for sale section
yup - http://foc-u.co.uk/index.php?topic=24072.new#new (http://foc-u.co.uk/index.php?topic=24072.new#new)
