Date: 26-04-24  Time: 01:53 am
Author Topic: FZS600 lights not working  (Read 1059 times)
Stogie777
« on: 24 May 2020, 02:04:39 pm »
Hello,
I’ve got a problem with my 2001 boxeye. Seems to be very similar to some other issues on here but they were on a fox eye and fixed by replacing a relay that doesn’t exist in the boxeye.
Essentially with lights switches on side or dipped, full beam on or off I get no lights at all. If I pull the flash trigger one side does come on. All brake lights and indicators function normally.
I’ve taken apart the right switch gear and all contacts look clean.
Any ideas?
  • Foc-u Brake Doctor
Re: FZS600 lights not working
« Reply #1 on: 24 May 2020, 02:56:27 pm »
It's more than likely an earthing issue, either within the switch or in one of the connecting plugs/blocks.  Put a tester on the circuit check for continuity.
Later
« Reply #2 on: 24 May 2020, 05:54:16 pm »
:agree
Look at the cable from the light switch and check its all plugged in properly under the tank.
TOM VR46
  • NEW TO FAZER FORUM
« Reply #3 on: 24 May 2020, 07:44:15 pm »
One wee idea as this happened to me before. Check ignition wires. I went all through wires, connectors , switches but not ignition switch. Someone said put key in , switch on and headlight switch on, and gently move wires at the bottom of ignition, even steer left to right a few times and see if they come on. They did. I had broken wire in the ignition. And if theres a problem with it, theres a post somewhere on here to take it apart.
Stogie777
« Reply #4 on: 24 May 2020, 11:18:39 pm »
Thanks for your help gentlemen.
Traced the cabling inside the nest of rat’s tails under the tank and found a very burnt out connector. Promptly rewired it, a bit fiddly due to cable length but got it sorted.
« Reply #5 on: 25 May 2020, 10:44:02 am »
 :thumbup :)
Later
