Date: 26-04-24  Time: 12:07 pm
Author Topic: Nikko G-pack  (Read 5835 times)
Superfour Tom
    • - Triumph TT600
Nikko G-pack
« on: 23 July 2013, 02:00:04 am »
just enquiring if anyone has one of these installed, Would like to remove that pesky limit on the first gear.[size=78%] [/size][/size]and also see if it removes the "run like crap mode" when removing the speedo drive as i have done. (although it is barley noticeable)Problem is.. i have removed the speedo drive and most of the pictures i have seen on the net show the deice going in between the drive and the loom, but others go between the ecu and the loom, which one is used for the fazer?Thanks,[size=78%]
[/size]Tom[size=78%]
"Its a Fazer Jim, but not as we know it"
andybesy
Re: Nikko G-pack
« Reply #1 on: 23 July 2013, 02:04:17 am »
1st gear limit?
Superfour Tom
    • - Triumph TT600
Re: Nikko G-pack
« Reply #2 on: 23 July 2013, 02:06:46 am »
Thorn
Re: Nikko G-pack
« Reply #3 on: 23 July 2013, 04:18:25 am »
Why do you want to remove the 13.5k limiter?
Re: Nikko G-pack
« Reply #4 on: 23 July 2013, 09:01:10 am »
I'm not clear on how the Nikko G-pack works, but was under the impression that it alters the fueling map... which would require a fuel injection system in place of the carbs. But if it only alters ignition timing it won't know what the engine revs are if it's meant to be connected between the (missing) speedo sensor and the ignition circuit.
« Last Edit: 23 July 2013, 09:55:59 am by Fazerider »
Superfour Tom
    • - Triumph TT600
Re: Nikko G-pack
« Reply #5 on: 23 July 2013, 11:54:42 am »
Not sure whats what with the pack, id like to have it just to at least see if it gets rid of the midrange problems.
And it may be that i have no speedo hooked up that i have such a low limit in first? I'm not sure what it is at, but its definitely there, and annoying.
EDIT: NOT FIRST, SECOND GEAR
« Last Edit: 23 July 2013, 12:03:32 pm by Superfour Tom »
JZS 600
    • - VFR 1200 FD
Re: Nikko G-pack
« Reply #6 on: 23 July 2013, 12:35:00 pm »
Fuelling map on the carbs?
Superfour Tom
    • - Triumph TT600
Re: Nikko G-pack
« Reply #7 on: 23 July 2013, 12:36:58 pm »
Alters the Retard/Advance.
JZS 600
    • - VFR 1200 FD
Re: Nikko G-pack
« Reply #8 on: 23 July 2013, 12:37:36 pm »
mmm, really?
Superfour Tom
    • - Triumph TT600
Re: Nikko G-pack
« Reply #9 on: 23 July 2013, 12:42:33 pm »
mmm, really?
Apparently. Similar thing with the old Gsxr's, forces the ecu to think the bike is at a certain speed. Rather than think its doing the speed it is doing, Or 0mph all the time.(in my case)
Raises the rev limit to 12k on second and third too. although its probably not wise to go that high)
« Last Edit: 23 July 2013, 12:46:12 pm by Superfour Tom »
Lawrence
    • - CBR1100XX Super Blackbird
Re: Nikko G-pack
« Reply #10 on: 23 July 2013, 12:46:18 pm »
What rev limiter?  I'm sure I've had mine past 12k in 1st-3rd... :look
Superfour Tom
    • - Triumph TT600
Re: Nikko G-pack
« Reply #11 on: 23 July 2013, 12:49:46 pm »
Who knows, I'll check later.. then repost.
Hope to god i don't have a restricted ecu or something..  :(
« Last Edit: 23 July 2013, 12:50:59 pm by Superfour Tom »
JZS 600
    • - VFR 1200 FD
Re: Nikko G-pack
« Reply #12 on: 23 July 2013, 12:53:03 pm »
I'm going to check tonight!
Superfour Tom
    • - Triumph TT600
Re: Nikko G-pack
« Reply #13 on: 23 July 2013, 12:55:26 pm »
Please do, Hope my ecu isn't cooked or something. If you hit a limiter, tell me the revs
    • - FZS600 00-01
Re: Nikko G-pack
« Reply #14 on: 23 July 2013, 01:13:36 pm »
Mine definitely revs up to past 12k in 1st-3rd - don't think I've quite gotten there in 4th or higher as I ran out of "runway" / "drag strip" ;)
Superfour Tom
    • - Triumph TT600
Re: Nikko G-pack
« Reply #15 on: 23 July 2013, 01:18:00 pm »
I'll check mine now, give me 10 mins
Skippernick
Re: Nikko G-pack
« Reply #16 on: 23 July 2013, 01:25:47 pm »
Its a carburated  engine, there is no ecu.
Lawrence
Re: Nikko G-pack
« Reply #17 on: 23 July 2013, 01:38:18 pm »
How does the rev limiter work?  Is it off the clocks?
Superfour Tom
    • - Triumph TT600
Re: Nikko G-pack
« Reply #18 on: 23 July 2013, 02:11:51 pm »
yadda yadda, ecu, cdi.. Whatever.
Just took the bike out and cant get past 10.8 which i suppose is high enough but certainly still annoying when canning it in low gears, As far as i know it was like this before i swapped the engine and switched to r1 front end
Re: Nikko G-pack
« Reply #19 on: 23 July 2013, 02:12:58 pm »
I see... kinda.
I must admit I've never noticed a lower rev limit in first or second (or neutral, come to that), but the speedo sender does feed the ignitor unit as well as the speedometer itself and I can't think of any other reason for it to do so… there's no ram air system that might justify modifying the advance for example.
If this is the device then it looks as if it requires the speedo sender to be in place anyway (presumably doubles the frequency of the pulses or something) this will make any speedometer read wrong which would be why they say it's not for road use.
« Last Edit: 23 July 2013, 06:24:27 pm by Fazerider »
clayt74
Re: Nikko G-pack
« Reply #20 on: 23 July 2013, 05:13:07 pm »
Make sure your airfilter is OK and that nothing else is restricting the airflow?
With this really hot n humid air at the mo you could just be suffercating the engine?
Maybe?
Just a thought
Skippernick
Re: Nikko G-pack
« Reply #21 on: 23 July 2013, 07:15:22 pm »
Or it has different gearing maybe, would that do it?
Punkstig
Re: Nikko G-pack
« Reply #22 on: 23 July 2013, 07:16:20 pm »
Nah, its all related to not having the speedo sensor fitted as someone else had mentioned in other posts.
With regards to the g-pack I've read nothing but complaints about them, apparently its just a resistor inside a box which obviously sends a false signal of some description!
Some say...
Mark YPVS
    • - R1
Re: Nikko G-pack
« Reply #23 on: 24 July 2013, 01:57:48 pm »
Just tried mine 13500rpm in 3rd limiter chimes in ( just shy of 120mph)
i used my drive way to test the speed revs etc  :lol :lol
Mark
Skippernick
Re: Nikko G-pack
« Reply #24 on: 24 July 2013, 07:00:50 pm »
Mark
Really, that means it takes 3 more gears to cover the last 20 odd mph.
