Date: 25-04-24  Time: 08:52 am
Author Topic: Cant get pressure in the brakes :(  (Read 2041 times)
alexanderfitu
« on: 18 April 2013, 03:06:57 pm »
Hi all
I have recently changed out all the lines in my 1991 XJ600. I have replaced them all with goodridge lines.
I have also overhauled the master cylinder. (new mc kit)
The problem I have, is that I cant get the brakes to pump up, I have clear fluid showing at the bleed nipples on the front fork, but no pressure in the lever.
Any thoughts?
    • - FZS600,CB400/4,X7,CB250
Re: Cant get pressure in the brakes :(
« Reply #1 on: 18 April 2013, 03:45:25 pm »
what bleeding method are you using ?
richfzs
« Reply #2 on: 18 April 2013, 03:53:59 pm »
Not a very good one :lol
Sent from my Nexus 4 using Tapatalk 2
    • - FZS600 00-01
« Reply #3 on: 18 April 2013, 04:13:18 pm »
If you aren't getting pressure then there must be a leak somewhere in the system. Is brake fluid leaking from anywhere obvious? Make sure the reservoir never gets too low otherwise you will draw air in...
I know I am stating the obvious, but its the best place to start :p
alexanderfitu
« Reply #4 on: 18 April 2013, 04:28:31 pm »
Pump lever 2-3 times, pull lever all the way, open bleed nipple, close bleep nipple, release lever, rinse repeat.
alexanderfitu
« Reply #5 on: 18 April 2013, 04:29:13 pm »
Defo no leaks! I have gone over every joint, cant see any leaking fluid, nor any from the calipers.
richfzs
« Reply #6 on: 18 April 2013, 04:32:07 pm »
And you're certain the fluid isn't dropping too low in the reservoir at any time?
Sent from my Nexus 7 using Tapatalk 2
alexanderfitu
« Reply #7 on: 18 April 2013, 04:33:40 pm »
100 percent.  I'm keeping it topped up.  Pulling on the lever does move the calipers a tiny bit.  Making me think there is still lots of air in the system.
Sent from my GT-N7000 using Tapatalk 2
richfzs
« Reply #8 on: 18 April 2013, 04:51:49 pm »
Try the "clamp the brakes on" and leave overnight trick. Use a bungy our something to hold the lever back. The pressure (such as it is) encourages any air to bubble up and aid bleeding.
alexanderfitu
« Reply #9 on: 18 April 2013, 04:52:56 pm »
Will give that a go with the calipers ip on the mudguard it should help.  Thanks
richfzs
« Reply #10 on: 18 April 2013, 04:55:52 pm »
Might be a silly question, but if you've got the calipers up on the mudguard, are the bleed nappies still at the top of the calipers (or at least the bit of the caliper that has fluid in it?
Razgruff
    • - Yamaha TT600R XS750
« Reply #11 on: 18 April 2013, 06:26:54 pm »
Did you check the barrel of the master cylinder, was the overhaul kit in date?
Rubber is a perishable part and these kits have expiry dates.
Sounds like the fluid is passing back behind the plunger somehow, if you are sure you have no leaks or airlocks.
Rubber Brake parts shrink when dry, I suggest dismantling the Master Cylinder again and soak the Master Cylinder rubber parts in Brake fluid and checking them to ensure that they are the correct parts.
Also check that you re assembled it correctly
richfzs
« Reply #12 on: 18 April 2013, 06:27:59 pm »
fecking autocorrect  :rollin :rollin
alexanderfitu
« Reply #13 on: 18 April 2013, 06:28:27 pm »
yes yes and yes :)
All soaked in brake fluid whilst I was dismantling the old MC, I also laid out the parts in order that I removed them.
I pulled the hole thing apart again as I missed the washer initlaly and checked the bore at the same time, all clear.
Anyway, I have sorte it now :) there were air pockets in the caliper bodies, pushing the pistons in further and then pumping them out again sorted it :) Nice firm lever now, thanks all!
Chris
« Reply #14 on: 18 April 2013, 06:42:13 pm »
*insert "hard" innuendo here*
Glad you got it sorted mate!  8)
Chris
« Last Edit: 18 April 2013, 06:43:13 pm by Chris »
alexanderfitu
« Reply #15 on: 18 April 2013, 06:45:42 pm »
Haha! I resisted in the post :)
« Reply #16 on: 19 April 2013, 10:52:15 am »
I had that problem when I put braded hoses on a bike a few years ago. No matter how much lever pumping or clamping back of the lever, nothing would shift the air. the answer was to rasie the capliper above the master cylinder and bleed it then refit it.
