Date: 26-04-24  Time: 08:42 am
Author Topic: Does exhaust leakage matter?  (Read 2991 times)
Jimmygixxer
    • - GSXR 750
« on: 14 April 2013, 03:16:55 pm »
After reassembling my micron exhaust, i noticed where the link pipe meets the headers there is a small amount of blowout.
Alot of people seem to try and get an airtight seal in these areas.
Does it make much difference to anything?   My bike will backfire a little bit off the throttle from highish revs, is this a possible factor or not?
Re: Does exhaust leakage matter?
« Reply #1 on: 14 April 2013, 03:31:46 pm »
Ideally it should be a good seal but i don't think it's a major.
My bike used to pop on deceleration, but it went away when i got the carbs balanced.
    • - FZS600,CB400/4,X7,CB250
« Reply #2 on: 14 April 2013, 04:31:54 pm »
could fail mot if tester spots it....if origanal steel pipes get them welded before it gets any worse  ;)
keno
    • - ZRX1200R 2006
« Reply #3 on: 14 April 2013, 04:45:57 pm »
Had that problem with my fazer a few years ago, i just bought some heat resistant sealant smothered it on then joined together and left to cure for 2 days,problem solved.
Mine was really bad so had no choice.
Young rider
« Reply #4 on: 14 April 2013, 05:07:51 pm »
mine does that too kinda like the popping noise.
never bothers me with the leaking bit.[size=78%] [/size]
Learning every day.
    • - FZS600 00-01
« Reply #5 on: 14 April 2013, 06:43:58 pm »
Isn't the popping noise due to a bit of fuel vapour that isn't burnt off when chopping the throttle at high revs combusting in the exhaust? Can't see it being anything to do with a small exhaust leak...
bwizz
    • - FZS600 02
« Reply #6 on: 14 April 2013, 07:24:05 pm »
My old fazer had a slight leak on the front pipes , It used to pop and bang on overun
sounded ok I thought at the time
Jimmygixxer
    • - GSXR 750
« Reply #7 on: 14 April 2013, 07:31:05 pm »
Thats what i thought, but seen a few people online saying thats what was causing their problem.
Jimmygixxer
    • - GSXR 750
Ton13
  • Tonie
    • - Honda VFR 750
« Reply #10 on: 14 April 2013, 11:17:40 pm »
i have a micron Exhaust and also have a small amount of leakage....
this is usually normal and is the condensation from when you first start up the bike.
ive never failed a MOT or had any problems with it....
ALSO, the popping noise is awesome, especially if you're going under a bridge or through a tunnel! :lol
Ride It Like You've Stole It
« Reply #11 on: 14 April 2013, 11:33:47 pm »
This fella explains the 'popping' quite well:
http://forum.motorcycle-usa.com/default.aspx?f=18&m=398516
    • - FZS600 00-01
« Reply #12 on: 15 April 2013, 12:11:01 am »
Nice find darrsi, was a good read :)
keno
    • - ZRX1200R 2006
« Reply #13 on: 15 April 2013, 10:44:11 am »
My fazer 600 & zrx 1200 both pop and fart on the overrun.
Zrx is the loudest but sounds great,its all part of the aftermarket replacements.
If it bothers you get jetted.
