according to manual :Oil quantity:Total amount:3.5 LPeriodic oil change:2.5 LWith oil filter replacement:2.7 L
Quote from: xlewisbdx on 30 January 2013, 04:54:22 pmQuote from: darrsi on 30 January 2013, 04:52:41 pmFrom empty, as you are changing the filter as well, you're safe to put in 2.5 litres straight off.Then, start the engine for 20-30 seconds so it coats the engine, switch off, and then watch the window, the oil will slowly rise up.If it's not enough add a bit at a time, then start engine again, switch off, then watch the window again.Repeat this process until the oil level is in between the metal markers at the side of the window.Make sure the bike's on a level flat surface on the centre stand though otherwise you'll get a false reading. I love you.... Now, now, control yourself, you have a bike to look after.......
I will be changing oil in mine. Do you know the measures for drain washer? Or link to websites would help. Fzs600 2002. Thanks.
You will find that you will have to undo & do it up with a ring spanner as you can't get a torque wrench or socket on it due to the frame. Just nip it up don't be tempted to over tighten as you will strip the threads.
Also for the sump plug, these are worth their weight in gold:
Regarding alternative methods on the oil filter, fust buy an oil filter socket, it makes it so much easier to change the filter.On another note, for you guys with un-original downpipes (motad/delvic), do they make the oil filter change harder?Also for the sump plug, these are worth their weight in gold:
