Date: 26-04-24  Time: 23:31 pm
Author Topic: Oil & Oil Filter change.  (Read 6240 times)
Re: Oil & Oil Filter change.
« Reply #25 on: 30 January 2013, 04:59:52 pm »
according to manual :
Oil quantity:Total amount:3.5 L
Periodic oil change:2.5 L
With oil filter replacement:2.7 L
Crikey, don't chuck 3.5 litres into the equation, i'm trying to make this easy!!
3.5 litres is in the factory, totally dry.
xlewisbdx
« Reply #26 on: 30 January 2013, 05:04:18 pm »
From empty, as you are changing the filter as well, you're safe to put in 2.5 litres straight off.
Then, start the engine for 20-30 seconds so it coats the engine, switch off, and then watch the window, the oil will slowly rise up.
If it's not enough add a bit at a time, then start engine again, switch off, then watch the window again.
Repeat this process until the oil level is in between the metal markers at the side of the window.
Make sure the bike's on a level flat surface on the centre stand though otherwise you'll get a false reading.  ;)
I love you.... :)
Now, now, control yourself, you have a bike to look after.......  :biker
Oh yeah, he gets all the attention first ;)
zielik
« Reply #27 on: 04 May 2017, 08:02:41 pm »
I will be changing oil in mine. Do you know the measures for drain washer? Or link to websites would help. Fzs600 2002. Thanks.
Zielik
« Reply #28 on: 04 May 2017, 08:38:37 pm »
Would just use the old one to be honest, the sump bolt is long with plenty of thread, it's not under any stress, and won't come loose or leak.
Don't go mad tightening the bolt up either otherwise you'll round it off.
« Reply #29 on: 04 May 2017, 08:46:56 pm »
Agree with darrsi, but if you want to replace with a new one you need a aluminium sump washer M14x20x1.5.
http://www.ebay.co.uk/itm/M14-X-20-X-1-5-MM-THICK-ALUMINIUM-SUMP-NUT-WASHERS-/270661455664
zielik
« Reply #30 on: 04 May 2017, 09:04:05 pm »
HI Darrsi and Bandit
Thank you very much for help. If I will manage to buy it in Edinburgh before the weekend (as it's too late for online order)  then I will use new washer if now then I go with the old one. I will use friend's torque wrench for tightening up so should be all good :-)
Thanks again
Zielik
Zielik
« Reply #31 on: 04 May 2017, 11:12:13 pm »
You will find that you will have to undo & do it up with a ring spanner as you can't get a torque wrench or socket on it due to the frame. Just nip it up don't be tempted to over tighten as you will strip the threads.
« Reply #32 on: 05 May 2017, 06:34:52 am »
That was my earlier point about not going mad tightening it up, you can't get a socket on the nut so unless you've got some fancy contraption then nipping up as bandit says is more than enough. If it was to leak, which it won't, then simply nip it up a little bit more.
Just make sure the ring spanner is on properly otherwise it will quite easily round off or damage the soft hex head of the bolt......been there, done that before.  :o
Jules-C
« Reply #33 on: 05 May 2017, 08:24:04 pm »
For some reason that escapes me the sump plugs seem to be made with pre-rounded corners to make them more prone to spanners slipping than normal bolt heads
kgjersda
« Reply #34 on: 05 May 2017, 09:17:44 pm »
Regarding alternative methods on the oil filter, fust buy an oil filter socket, it makes it so much easier to change the filter.
On another note, for you guys with un-original downpipes (motad/delvic), do they make the oil filter change harder?
Also for the sump plug, these are worth their weight in gold:
vinnyb
« Reply #35 on: 05 May 2017, 09:52:34 pm »
 Strictly speaking only one of them is, the rest won't fit  :lol
« Reply #36 on: 05 May 2017, 10:10:39 pm »
 :agree
Yeah, good shout, i have a set of these as well, really handy.
Dave48
    • - MT-07 Tracer
« Reply #37 on: 06 May 2017, 09:26:03 am »
I bought a set of these from Halfords in January and they have become my spanners of choice particularly in restricted areas. Money well spent!
