Hi all, went out of the bike today with no problem, came back turned bike off and decided to go back out, so ignition on press start & CLICK & the all the lights went out. Turned the ignition on & off several times & kill switch but still no electrics at all.
Put the bike in the garage & tried once more & the ignition switch worked with the instrument & neutral light came on, pressed the start button & click & no more electrics & haven't had them since.
Checked the 30 A switches on the start relay & they both look intact. Can some one give me some guidance on what I should be checking next?
The one thing that I haven't mentioned was that I fitted a Acumen gear indicator this morning with the correct plug in loom, but this was working o.k. when I was out.
Cheers.
