My 03 1000 is an import and the lights dip the wrong way. Some MOT places are more particular then others and it usually involves ignoring it or some insulation tape each year. Of course I can’t compare to how that would be tested outside of the UK.
Some models of bikes have their light beams set straight unlike cars etc & don't pitch to the left or right, not sure if the FZS600 is one of the though or if the beam can be adjusted. Which country are you going to.
Quote from: Trebus on 25 July 2019, 09:04:03 amMy 03 1000 is an import and the lights dip the wrong way. Some MOT places are more particular then others and it usually involves ignoring it or some insulation tape each year. Of course I can’t compare to how that would be tested outside of the UK.Maybe you could swap with Meldoxxas both 600 foxeye and 1000 have the same headlight.
