Yes the blue connector is plugged in...the black connector is actually a 15a fuse...one of the wires going to it is marked 6NR...the other wire didn't go anywhere so i cut it out. All the black wires have similar yellow bands but no numbers or other markings...
So i check to see if i have continuity between the black side of the sidestand (blue) connector and any of the black wire i have exposed...and indeed i do...on Nos. 5 & 6....confusing....???
At the risk of confusing him more can I throw my tuppence worth in? I think this is right but tell me if I’m wrong. There should be 9 black wires but he only needs to identify four of them to make the bike run? He needs the ground from the side stand, and that joins back to the Ignitor. And he needs the ground when the starter switch is pressed, and that joins to the cut-off relay. That’s all he needs. With a continuity test. If he turns the ignition ON, he puts one probe of his meter in the side stand Blue/Yellow, then touches the other probe off each loose black wire. When the meter beeps turn the ignition off, if the beeping stops when the ignition is off that loose black wire is the switched ground from the side stand. If the beeping continues it’s the permanent ground so repeat the test until you find the black wire where the beeping stops when you turn the ignition off. That side stand ground connects to a black wire in the 8 pin connector going to the Ignitor, so if he takes the 8 pin connector out of the Ignitor, touches a test probe to the pin with the black wire, touches the other test probe to the loose black wires, when the meter beeps that’s the wire going to the Ignitor. He should join the two loose black wires that he just identified together (side stand ground and black going to Ignitor). The other two wires that he needs to join together are the ground from the starter switch and a black wire going to the cut-off relay. If he connects a probe to the blue/white wire coming from the starter switch and connects the other probe to the loose black wires one loose black wire should beep. That’s the switched ground from the starter switch. Next connect a test probe to the black wire at the cut –off relay and the other probe to the loose black wires, one of them should beep. Join the two loose black wires that you identified together. (Ground from the starter switch and the black wire going to the cut-off relay) That should be all he needs to join. The rest don't effect the bike starting or running. (I think ) I was looking at the wiring diagram in that manual http://foc-u.co.uk/index.php?action=downloads;sa=view;down=4
Yes...any suggestions as to how to proceed...or have u had enuf ...???!!!!
