Date: 26-04-24  Time: 06:37 am
Author Topic: Tweaking suspension when fully-loaded  (Read 832 times)
roxburd
« on: 27 April 2019, 07:26:57 pm »
Hey all,
The little Yamaha manual is pretty good on describing where the suspension controls are and how to adjust them. But it says bugger-all about what adjustments you should be looking to make for different loads.
I don't usually bother adjusting the suspension at all as it's either just me (~80Kg) or me + light luggage or me + pillion for short trips and I've never felt it warranted messing with the set-up.
But I'm planning a long trip two-up fully loaded and I'm thinking that's gotta be worth a tweak on the rear pre-load at least (as that's where most of the load will be).
But I'm not sure what else if anything is likely to need adjusting.
Front pre-load - yeah, I guess so, to firm the front up a bit, especially under braking?
Front & rear compression - maybe? Especially on the front to firm it up under braking again?
Front & rear rebound - really don't know why that would be needed!
Any advice? Any recommendations for step-by-step guides?
Cheers,
Dave
celticbiker
      Fazer8
Re: Tweaking suspension when fully-loaded
« Reply #1 on: 27 April 2019, 10:20:00 pm »
If anything it's the damping that needs tweaking. It's a common misconception that adding preload stiffens the spring, it doesn't it just increases the shock length/ride height allowing for greater travel before bottoming out.
If you need a stiffer spring, you need a stiffer spring.
roxburd
« Reply #2 on: 31 May 2019, 11:00:49 am »
Well, just got back from the Isle of Man. I had a good play with pre-load and compression damping and it did make quite a difference, so much so that the suspension felt perfect on the ride there, two-up fully loaded, but when I was riding round the island one-up after dumping all the luggage I had to put the compression damping down again as the front was too stiff and harsh. You're dead right about pre-load, Celtic, just moves the rest position.
