Date:
20-04-24
Time:
01:59 am
Welcome,
Guest
. Please
login
or
register
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Forum
Basics
FAQ
Tips and Tricks
SMF's help
About
Links
Articles
Fazer1000/FZ1
FZ8
FZ6
FZS600
For any bike
Misc
Media
Downloads
FZS600 Fazer
fork oil / air gap ??
« previous
next »
Print
Pages: [
Author
Topic: fork oil / air gap ?? (Read 1206 times)
74eldiablo
Weekend Warrior
Main bike:
on:
20 March 2019, 10:08:21 am »
Ive just put some 15w oil in my 2001 forks with pre load adjusters.
465ml measured out correctly.
Pumped the forks to release air bubbles.
After 10 minutes each leg sitting i measured the air gap
It was way off the specified 132mm (at least 15 > 20mm off)
Should i add more oil to make the air gap the correct height or just leave the measured out 465ml
Thanks
Last Edit: 20 March 2019, 10:09:41 am by 74eldiablo
Logged
Club Racer
Main bike:
Re: fork oil / air gap ??
Reply #1 on:
20 March 2019, 02:56:33 pm »
With the inner fork compressed without the spring fitted,I personally with add more oil to the 132 mm level.
Logged
GP Hero
Main bike:
- Mk 1 Speed Triple
Reply #2 on:
20 March 2019, 03:16:12 pm »
Had this problem a year or so back on a thou. If I remember correctly the correct amount of oil meant the gap was far too small, meaning fluid would have to be removed. Spoke to a mech at a Yam dealer and he said ignore the airgap and stick with the prescribed volume.
Logged
GP Hero
Main bike:
Reply #3 on:
20 March 2019, 06:19:17 pm »
I had similar when i last did my oil.
Forks were empty, and the levels were measured out spot on, but the air gaps were different as well.
I made the air gaps the same and have never had any problem with handling at all.
Logged
Guest
Reply #4 on:
20 March 2019, 06:46:16 pm »
bad advice to ignore the air gap if its different from leg to leg then the spring pressure will be different as the air gap compresses with the movement of the forks so it will affect how the forks operate who ever told you otherwise is clue less and not a mechanic
Logged
74eldiablo
Weekend Warrior
Main bike:
Reply #5 on:
20 March 2019, 07:29:11 pm »
I already made the airgaps upto 132mm by adding extra oil, i just wanted to see what other people had experienced whilst doing this job.
So my intial gut feeling was correct as confirmed by most of you guys.
Thanks for your input.
Now im off to spray the top yoke ready to fit the new bars
Logged
GP Hero
Main bike:
Reply #6 on:
20 March 2019, 07:59:23 pm »
I add the recommended volume then add or remove a small amount to get the air gap equal in both forks and at the recommended height. I think this guy does suspension setup for track bikes. He talks about air gap in this video
Logged
Print
Pages: [
« previous
next »
FZS600 Fazer
SMF 2.0.18
SMF © 2011
Simple Machines
Crushing Theme by
Diego Andrés
XHTML
RSS
WAP2
