so in my haste to give my new ‘04 thou a thorough going over I stripped the exup for a clean and regrease. Rear bolt snapped, this was well before Xmas
So I left it alone as didn’t have any taps or easy outs etc, and it just sat there stripped in garage for a month
Anyway, Mate came over today and drilled it and retapped the thread for me
so I’m a happy man. Just put it back together after giving the shaft a clean up with some emery, then a smear of copper grease on the moving parts and the new bolts I got. It is slightly out of adjustment with the ignition on, but functions fine and it goes like a bastard anyway as I just found out. I’ll have a go at adjusting the cables and center the fork thing over the hole after work one evening this Week.
Then it’s an oil change and pray for some dry days that ain’t so cold so I can use it a bit. It’s bogging a bit at low revs but it’s stood for a year prior to me buying it off its old owner. I’m thinking a couple of tanks of super through it and some serious rape should clear them carbs out
